Sorry if this is an obvious question, I’m still trying to get my feet wet on HABApp
I noticed that the the scheduler for on_sun_dawn and on_sun_dusk need the location to be set (shame on me, could have read the docs first) which can be done in config.yml
On the other hand, I have the same location information already available in runtime.cfg and therefore somewhere in the live configuration of OpenHAB.
Is there a way to fetch this information from OpenHAB instead of hardcoding it in two seperate places (runtime.cfg or interactive on one side, and config.yml on the other side)? A startup rule which does this would be excellent
Currently there is no easy way. You could read the value through the RestAPI and then programmatically create a new config.yml but that seems like overkill
