I get this warning all the time and I’m not sure where the error is in my binding that’s causing it. I’d really appreciate any pointers on what to look for to fix it.
What I don’t understand is how it would even be possible for a function that is a member of the handler object to even exist after the handler object is gone let alone do something. Maybe I’m totally misunderstanding the handler life cycle (zero Java experience). I thought the handler was created in memory when the thing was first created (or the system boots) and persisted until the thing was removed or the system shuts down. Is the handler disposed/recreated between jobs scheduled with fixed delay?
I did find that I’d somehow lost my dispose method leaving a hanging polling job. Oops. Fixing that dramatically cut down the errors, but I’m still getting some.
I’ve noticed when developing a binding that when I put my freshly built jar in the addons-folder and start OH, the old version somehow lingers in the cache and is started first. Then it is stopped and the new version is loaded. If there are any remaining scheduled jobs that aren’t properly cancelled though, these continue to run, trying to update the thing. Can it be something like that you’re experiencing? Make sure you use the dispose() method in your handler to clean everything up.
For reference, I’m working on Windows using intellij. I haven’t managed to automate the process of starting OH, so I have to do it manually after copying the add-on jar.
