I live in Sweden and I am having a bit of an issue with item labels and getting them to be encoded correctly all the way. I try to illustrate the issue (using the Safari browser, but i think the issue is present also in chrome - I have seen similar things happening, but I just have not investigated it to the same extent).
Ok,I may have a label like this, with some characters garbled. They were of course entered in from the PaperUI on the same browser.
So, I would like to know if there is some way - like a strategy, setup or something else - that would allow my item labels to work well with the system.
Yes, that seems to be the issue. It was set to ISO 8859-1 Swedish and not UTF8 (and perhaps I had not set it to Swedish at all, I cannot be sure). Anyway, it seems to work now. Thanks!
Sorry, but I need to re-open this thread, as I am now in a situation that is related to this change.
I set my locale to sv_SE.UTF-8 using the openhabian config tool and everything seemed fine. Now (perhaps after the first reboot, perhaps second - I don’t remember) I am getting these messages on most commands on the ssh console
$ sudo update-locale sv_SE.UTF-8
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "sv_SE",
LC_ALL = "sv_SE",
LC_CTYPE = "sv_SE",
LANG = "sv_SE.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("sv_SE.UTF-8").
*** update-locale: Error: invalid locale settings: LC_CTYPE=sv_SE LC_ALL=sv_SE LANGUAGE=sv_SE
I cant see that I am setting LC_TYPE somewhere locally for the user
Yes, I got this to work now. Somehow. The issue “I think” may have been related to my having set sv_SE first (latin1) and then wanted to switch to sv_SE. I don’t know, whatever I did it never switched from sv_SE in /etc/default/locale and so on. It was never regenerated, even though it says that it did.
But, I was able to switch to the UTF-8 encoding version by making sure that I have latin 1 sv_SE and sv_SE.UTF-8 locale generated,manually editing the /etc/default/locale manually, rebooting and THEN go into openhabian-config and select and generate the locales again, and then rebooting again.
Not sure why and what was forced to be re-generated by this procedure, but it seems to work now.
No I just wish that there was an easy way to change all the erroneous characters in things’ and items’ labels…
