Hey everybody! It’s my first day ever using openHAB2, so please be gentle.
I am trying to link my MyQ garage door hub to my Google Home app, and it seems as if openHAB + cloud is the way to go about doing this.
I’ve gotten fairly far with this whole process, but am failing at getting items to show up in https://myopenhab.org/items.
Here’s what I’ve done:
Found the latest fixed version of the MyQ bindings and manually installed it to my openHAB setup.
Configured the MyQ binding, used the inbox in paper UI to create Things (using simple mode?) which appears to have automagically created links and items.
Configured Openhab cloud to show as online and allow me to access my dashboard.
However, when I look at the items page for cloud, I see nothing.
I went into the services config in paper UI and selected the info I wanted to “expose”, and waited a bit, nothing shows on the items page.
I read somewhere that it’s possible that I need to change the device state, so I did that, but it doesn’t do anything.
I tried restarting my docker container, no change.
I tried removing the “expose” settings, nothing. Re-add, nothing.
I also read somewhere that I need to properly tag exposed items? But if they’re auto created, I see they’re stored in a json file instead of a .items file, so I’m not sure how to modify the tag.
So, my question is - can someone tell me how to use Paper UI (or something else) to set up control of my garage doors via google home, from start to finish? I feel like I’m missing something simple that I just don’t know to do because I’m new to this system.
Any help would be greatly appreciated. A few pointers and a small example should be all I need. Cheers!
