I want to toggle two lights on/off with one switch.
How do I add such a switch to the main page.
If I add a toggle switch, I am only able to add one item to it.
Each item can have 0…N channel links. Other way is creating a group item which will contain both your items. Then you will retain ability to control each light individually.
Thanks, Creating a group item worked for me.
