- Platform information:
- Hardware: Raspberry Pi
- OS: Raspbian 9
- openHAB version: 2.4
So I have been busy trying to work out my rule to utilize my Philips Hue Motion sensor to do what I would like. For the most part, it works. Here is my code so far:
var Timer motionTimer = null
rule "SKJ Motion Sensor ON"
Item MotionSensorPresence received update ON
if (AstroSunDown.state == ON && Mensen_Thuis.state == ON && Bureaulamp_Slaapkamer_Jasper.state == OFF && J_Slaapkamer_Plafondlamp.state == OFF) {
Plafondlamp_Slaapkamer_Jasper_Brightness_Slider.sendCommand(Bri)
else if (AstroSunDown.state == ON && Mensen_Thuis.state == OFF && J_Slaapkamer_Plafondlamp.state == OFF) {
Plafondlamp_Slaapkamer_Jasper_Brightness_Slider.sendCommand(75)
motionTimer = createTimer(now.plusSeconds(60), [ |
MotionSensorPresence.sendCommand(OFF)
motionTimer = null
J_Slaapkamer_Plafondlamp.sendCommand(OFF)
else {
motionTimer.reschedule(now.plusSeconds(60 ))
So a quick run down how it works: When I am home (Mensen_Thuis = on), I don´t want the script to turn off my lights. When I am not home and someone has to get something from my room, I want the light to turn off after 60 seconds if there is no more movement, otherwise reschedule the timer.
So far so good, the script works. Unfortunately, when the states of above items are in such a way that the script imideatly reaches the last esle (Sun is up, I´m not home and/or one of my lights are on), my system gives an error.
Rule 'SKJ Motion Sensor ON': cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.reschedule(org.joda.time.base.AbstractInstant) on null
Now, I have searched for an answer, but I did not find one (or understood it right). Does anyone know what is going wrong in my script?
(P.S. I know my item names are not good, but that is something I still need to find time for in order to change )
Threads I read:
