Timer Rule Problem
Hi There
I’m having some issues with my timer rule, hope someone can help me out.
import org.openhab.model.script.actions.Timer
rule "Nilan Humidity OFF Forseret"
        	Item Nilan_Input_RH changed
		delayTimer = Timer.createTimer(now.plusSeconds(30))
       	        sendCommand(Nilan_Control_VentSet,2)
		sendCommand(Smarthouse_Motorventil, OFF)
       	        delayTimer = null
I’m getting this error, and have been trying to search for what this means
14:20:47.551 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Nilan Humidity OFF Forseret': 'createTimer' is not a member of 'java.lang.Class'; line 70, column 16, length 38
14:20:47.551 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Nilan Humidity ON Forseret': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.lib.NumberExtensions.operator_plus(java.lang.Number,java.lang.Number) on instance: null
Look at this Example.
The code to be performed after the time has run-out has to be placed within “[ |” and “]” instead of the curly brackets .
After code change it still gives me this error:
15:03:08.240 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Nilan Humidity OFF Forseret': 'createTimer' is not a member of 'java.lang.Class'; line 72, column 16, length 176
You seem to have more in the rule file (at least 72 lines!) and the createTimer is defined as something else before!
Yes you are right I have, but I can’t see that createTimer is defined before.
import java.util.Random
val String logNamePresence = "presence"
var Timer presenceTimer = null
var Timer timer = null
val resList = newArrayList("640/480", "320/240", "480/360")
val urlList = newArrayList("http://www.fillmurray.com", "http://www.fillmurray.com/g",
                 "http://www.placecage.com", "http://www.placecage.com/c", "http://www.placecage.com/g")
val Random random = new Random()
var Timer delayTimer = null
rule "Humidity Average Nilan Inlet "
    Item Nilan_Input_RH received update
    Nilan_Input_RH_Avrg.postUpdate(Nilan_Input_RH.averageSince(now.minusHours(0.5)))
rule "Nilan Udluftning Max Speed Kl 06.00 & 18.00 hver Dag"
	Time cron "0 00 06 * * ?"
	or
	Time cron "0 00 18 * * ?"
	sendCommand(Nilan_Control_VentSet, 4)
rule "Nilan Udluftning Normal Speed Kl 07.30 & 20.00 hver Dag"
	Time cron "0 30 07 * * ?"
	or
	Time cron "0 00 20 * * ?"
	sendCommand(Nilan_Control_VentSet, 2)
rule "Nilan Humidity ON Forseret"
		var Number Humidity=(Nilan_Input_RH_Avrg.state)
		Humidity=Humidity+0.1
		Nilan_Input_RH_Trig.postUpdate (Humidity)
		if(Nilan_Input_RH.state >= Nilan_Input_RH_Trig.state){
		sendCommand(Nilan_Control_VentSet,4)
		sendCommand(Smarthouse_Motorventil, ON)
	    if(delayTimer == null) {
		delayTimer = Timer.createTimer(now.plusSeconds(30), [|
		   Nilan_Control_VentSet.sendCommand(2)
		   Smarthouse_Motorventil.sendCommand(OFF)
       	        delayTimer = null
	else {
        delayTimer.reschedule(now.plusSeconds(timeoutMinutes))
  delayTimer = createTimer(now.plusSeconds(30)) [|
  delayTimer = null
Fresh eyes :slight_smile:
Thanks so much, works perfect …
import org.openhab.model.script.actions.Timer //this import is only needed in openHAB1
val int timeoutMinutes = 30  //timeoutMinutes wasn't defined yet!
        delayTimer = createTimer(now.plusSeconds(30), [|
            delayTimer = null
    else {
should also work. In fact, it’s way better to use the methods [Item.sendCommand(value)] instead of actions [sendCommand(item,value)] (see sendCommand() Documentation - #9 by rlkoshak and http://docs.openhab.org/configuration/rules-dsl.html#sendcommand-method-vs-action)
It’s always a good Idea to check if the timer is initialized.
I don’t understand the difference between createTimer(int) [| ] and createTimer(int,[| ]) but in the end both are ok.
The error in first place was the Timer. before createTimer, this is not allowed in the rules DSL.
From the xtend docs:
When a method call’s last parameter is a lambda it can be passed right after the parameter list. For instance if you want to sort some strings by their length, you could write :
Collections.sort(someStrings) [ a, b |
  a.length - b.length
which is just the same as writing
Collections.sort(someStrings, [ a, b |
  a.length - b.length
Since you can leave out empty parentheses for methods which get a lambda as their only argument, you can reduce the code above further down to:
textField.addActionListener [
  textField.text = "Something happened!"
So ultimately both versions are the same. It is just a little bit of what is often called “syntactic sugar.” I personally prefer passing the lambda inside the parens as an argument rather than after because it makes it more explicit that the lambda is an argument to the function and nothing magic is going on.
Would there be a way to have a countdown timer shown on my site map?
In the below rule, I want to have the delayTimer remaining time shown - someone who can help me ?
        	Item Nilan_Control_VentSet changed from 2 to 4
 		delayTimer = createTimer(now.plusMinutes(20)) [|
 		delayTimer = null
It’s not easy but others have posted examples on the forum.
The trick of it is you need to have a timer that only sleeps for a second, updates a Number Item with the total amount of time remaining, then gets recreated to sleep for another second.
Thanks for your hint, I got it working :slight_smile:
Quite difficult to achieve this, but definitely worth it.
