I have been playing with OH1 and OH2 now for a couple of weeks and have decided that I will proceed with OH2. I know it is currently under development awaiting the first official release , but what exists so far is superb and is working well.
So far, I have just been editing the demo.sitemap files. I now want to create my own sitemap with my own name (e.g. cowen.sitemap). In which configuration file do I configure the new sitemap name?
I am currently presented with a page that allows me to choose which UI I want to use. If I select one of these, I then see the âServer Errorâ message. My assumption was that this is because the system is configured to use the âdemoâ sitemap by default. I can change the URL of course as you suggest, but I donât want to manually edit this each time or create multiple bookmarks. In the end I prefer to go the OH2 welcome screen and just jump to the UI from there for my sitemap.
Maybe a nice addition here would be the possibility to select the sitemap in the case that multiple sitemaps are configured - I donât know if the mechanism behind supports multiple sitemaps. In my case, 1 is enough.
Hi further to this, when I change the setting, this works perfectly. However, if I reboot the Pi, the demo sitemap is searched for again. I have to go and again reset the sitemap setting.
Actually, I found the file where this is defined and changed the value manually. But for information, changing this value in the paperui did not update the file.
# Defining the default sitemap to use
org.eclipse.smarthome.basicui:defaultSitemap=bota
# The icon type to use, either png or svg
org.eclipse.smarthome.basicui:iconType=svg
