Hi All,
I am running OpenHAB2 v4.0.4 on my Raspberry Pi 3 with Raspbian Jessie using the Z-Wave Binding 2.0.0.SNAPSHOT on and a Z-Stick Gen5 USB bridge and a Leviton DZPD3 dimmable switch. These are the only two devices I have configured.
I am trying to test my Leviton DZPD3 (http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/322) via the REST interface and I can not figure out how to turn the DZPD3 off/on or set a dimming level.
Using the OpenHAB2 Swagger REST UI I used the /items GET method to get the device name which returns the item I am interested in:
{ "members": [], "link": "http://192.168.1.23:8080/rest/items/zwave_device_eaae424f_node2", "state": "NULL", "type": "GroupItem", "name": "zwave_device_eaae424f_node2", "label": "Patio Lights", "tags": [ "thing" ], "groupNames": [] }
Notice the state value is null, I am not sure that is correct.
Then I tried to use GET /items/{itemname}/state which returns HTTP 200 OK with this body:
null
Then I tried to use PUT /items/{itemname}/state which has a field for body with examples such as ON, OFF. With either option I get error 400 Item state null
with the body of:
{ "error": { "message": "State could not be parsed: 100", "http-code": 400 } }
The OpenHAB log file contains:
Received HTTP PUT request at 'items/zwave_device_eaae424f_node2/state' with an invalid status value 'ON'.
I also tried to use POST /items/{itemname} with some of the suggested body examples and I get another 400 Item state null
with the body containing HTML stating:
Problem accessing /rest/items/zwave_device_eaae424f_node2. Reason: Bad Request
OpenHAB log shows the following for the POST request:
Received HTTP POST request at 'items/zwave_device_eaae424f_node2' with an invalid status value 'ON'.
My question is what am I missing? How do I know what commands a device can accept and the structure to send them?
