Hello all,
I am in the process of creating my first widget. The widget should access the members of the group gKuecheHVAC. I tried in the widget code to access the group member nKuecheSoll via props.item+“_nKuecheSoll” (The groupitem gKuecheHVAC was assigned to the parameter item). Unfortunately, this does not work for me. Does this not work in general or do you have any idea what I am doing wrong here?
The group is created as follows:
Group gKuecheHVAC "Küche Fußbodenheizung" <temperature> (gKueche) ["HVAC"]
Number nKuechentemperatur "Temperatur Küche [%.1f °C]" <temperature> (gKuecheHVAC) ["Measurement", "Temperature"] { channel="knx:device:bridge:dTastsensorKueche:Temperatur" }
Number nKuecheSoll "Soll [%.1f °C]" <temperature> (gKuecheHVAC) ["Setpoint", "Temperature"] {channel="knx:device:bridge:dHeizaktorEG:T_Kueche_Soll"}
Number nKuecheStellwert "Stellwert Küche in % [%.1f %%]" <temperature> (gKuecheHVAC) ["OpenLevel", "Valve"] {channel="knx:device:bridge:dHeizaktorEG:T_Kueche_Stellwert"}
Number nHVACMode "HVAC Betriebsart [%d]" <temperature> (gKuecheHVAC) ["HVAC"] {channel="knx:device:bridge:dHeizaktorEG:HVAC_Kueche_Status"}
Number nHVACState "HVAC Status [%d]" <temperature> (gKuecheHVAC) ["HVAC"] {channel="knx:device:bridge:dHeizaktorEG:HVAC_Kueche_Status"}
uid: ATest
tags: []
props:
parameters:
- description: Titelzeile
label: Titel (wenn leer, dann Gerätename)
required: false
type: TEXT
- context: item
description: Thermostat Item
label: Item
required: true
type: TEXT
timestamp: Dec 15, 2022, 8:18:27 PM
component: f7-card
slots:
content:
- component: oh-stepper-card
noShadow: true
color-theme: gray
item: = props.item+"_nKuecheSoll"
min: 5
max: 30
step: 0.5
- component: f7-card
title: '=(props.item) ? "State of " + props.item : "Set props to test!"'
footer: =props.prop1
content: =items[props.item+"_nKuecheSoll"].state
I would be grateful for any advice.
