Gad_Ofir
(Gad Ofir)
October 24, 2018, 3:10pm
6
Install Karaf Webconsole (works also on Windows)
do you know how to do this?
edite the org.ops4j.pax.url.mvn.cfg file and add the maven repository in the last line:
org.ops4j.pax.url.mvn.repositories=
https://dl.bintray.com/openhab/mvn/online-repo/2.1@id=openhab@snapshots ,
https://repo1.maven.org/maven2@id=maven.central.repo
then need to install some web console?what is this?
do i need to install maven or is it a part of OH?
Dim
(Angelos)
October 24, 2018, 4:57pm
7
First, add the maven repo at the end of your org.ops4j.pax.url.mvn.cfg file
then…
Gad_Ofir:
yes, enter in the OH2 console (openhab-cli console
or in windows the Karaf console when you run start.bat) and issue the following command: feature:install webconsole
https://karaf.apache.org/manual/latest/webconsole
no, the maven repo is an online storage of files/etc. when you issue the above command, OH2 will download from maven repo the necessary files to install the webconsole
when installed, you can access it from: http://localhost:8080/system/console/logs
(login using: openhab/habopen)
Gad_Ofir
(Gad Ofir)
October 24, 2018, 6:07pm
8
very cool thank you!
i will leave complete steps for noobs, its the best that i can do
in karaf type “feature:install webconsole”
go to http://localhost:8080/system/console/logs
one more Q i see allot of junk
any way to filter here ?
beside the log level of Error debug…
rlkoshak
(Rich Koshak)
October 24, 2018, 6:08pm
9
Some expanded things one can do with 1 with pipes and grep:
I’ve been seeing a lot of posts lately about people wanting to eliminate certain events from their events.log. This posting is to show that doing so is not only a bad idea but unnecessary.
First, I’ll apologize to the Windows users out there. I don’t know the right commands to do this on Windows without installing MinGW, Cygwin, or Linux Subsystem for Windows. Below I include both Posix (will work for Linux, iOS, BSD, and those addons to Windows listed to the left) and the Windows Powershell eq…
Gad_Ofir
(Gad Ofir)
October 24, 2018, 6:13pm
10
thanks Rich very helpfull!
still i was looking for software like “fidler” that have maybe a GUI(i know you hate that :))
but all the above will help also thanks guys!
Dim
(Angelos)
October 24, 2018, 6:43pm
11
by the way, to get rid of this auth spam, edit org.ops4j.pax.logging.cfg and set log4j2.logger.audit.level = OFF
under # Security audit logger
when using the webconsole, every http request will log an auth attempt and another success, so you will get alot of auth spam in your logs.
KidSquid
(The Squid)
October 24, 2018, 8:53pm
12
I’m trying to add this on a Windows install and am running into a issue.
Error downloading mvn:org.apache.karaf.webconsole/org.apache.karaf.webconsole.instance/4.1.3
I have edited the org.ops4j.pax.url.mvn.cfg file and placed the REPO1 url.
I have restarted OH,
Ran feature:install webconsole and still receive the error.
I am currently on OH 2.3.0-snaphsot, Build 1204
Any suggestions?
Dim
(Angelos)
October 25, 2018, 1:25am
13
KidSquid:
Any suggestions?
you should add the maven repo at the end of the file:
org.ops4j.pax.url.mvn.repositories= \
https://dl.bintray.com/openhab/mvn/online-repo/2.3@id=openhab, \
this example is from a 2.3 stable (so line 2 maybe a bit different if you are on 2.3 snapshot)
by the way: the webconsole is not that great
KidSquid
(The Squid)
October 25, 2018, 1:32am
14
I did not have the trailing “\” on the first line…that did the trick - Thank You!
Any other suggestions for a log viewer for a Windows machine? I’m sick of opening the file and scrolling to the end each time when I am working on something.
Dim
(Angelos)
October 25, 2018, 1:35am
15
I don’t know what to recommend cause I don’t use OH2 on Win. I usually work on Linux and I usually grep stuff.
This post: How to watch and look through logging is good and has Win info also
Gad_Ofir
(Gad Ofir)
October 25, 2018, 5:35am
16
Gad_Ofir:
habopen
ok ok new steps i forgat the maven!
in “org.ops4j.pax.url.mvn.cfg” file
add to file below rows
https://dl.bintray.com/openhab/mvn/online-repo/2.3@id=openhab ,
thanks! not that great but cool… maybe i can use node red to filter what i need
rlkoshak
(Rich Koshak)
October 25, 2018, 2:59pm
18
I can’t promise it works over samba, but the link I provided above on “How to watch and look through logging” also shows how to tail and filter out lines using PowerShell.
For example (copied from that post):
Only shows log entries that contain MyItem in events.log
Posix
tail -F $OH_EVENTS | grep MyItem
Windows
Get-Content $Env:OH_EVENTS -Wait | where { $_ -match "MyItem" }
Read the whole post for how to set the ON_EVENTS environment variable.
Gad_Ofir
(Gad Ofir)
October 25, 2018, 7:44pm
19
Hi just want to say!
not only for tracking logs this server management is very cool!
i recommend all to install this really!
one more Q, when trying to access with
https://home.myopenhab.org /system/console/logs
i get password promoted ,and its not the login from above…
can i even connect , and what is the pass and user?
KidSquid
(The Squid)
October 25, 2018, 7:51pm
20
It should be:
u - openhab
p - habopen
works fine for me - maybe you changed during install?
Gad_Ofir
(Gad Ofir)
October 25, 2018, 7:53pm
21
KidSquid:
openhab
and you are doing it from cloud or from your LAN?
Gad_Ofir
(Gad Ofir)
October 25, 2018, 7:59pm
23
i try from cloud …
seems cool to have CLI console from phone
but its asking for password, please try so i can know if i am spicsel hh
Gad_Ofir
(Gad Ofir)
October 27, 2018, 10:36pm
24
Hi i have issue on debian when i try to install
i have error
Error downloading mvn:org.apache.karaf.webconsole/org.apache.karaf.webconsole.instance/4.1.5
anything else i need to do for debian?
Gad_Ofir
(Gad Ofir)
March 25, 2019, 9:59pm
25
after new system upgrade i am still not able to install this , maybe someone has any idea how i can get this working?
i have the same error
Error downloading mvn:org.apache.karaf.webconsole/org.apache.karaf.webconsole.instance/4.2.1
just with diffrent version
i am talking about Karaf type “feature:install webconsole”
for web console of karaf
