Another thing that came to mind is typically the light is configured to go off a certain amount of time after the last motion was detected, meaning you only really track the ON states, not the OFF states of the motion sensor. As the person in the room moves around they keep rescheduling the timer until the room goes still for the given amount of time.
OK, now that I’m at a computer…
I’m glad to see either you came up with it independently or you are using the Design Pattern: Simple State Machine (e.g. Time Of Day).
So if I were to apply some of the above suggestions to make these rules more generic they would look something like (note, I’m not going to show all the Items involved).
import java.util.Map
val Map<String, Timer> timers = createHashMap // because you will want one timer per room
val Map<String, Timer> ctrlTimers = createHashMap
rule "Motion detected"
Member of LightMotionSenors received update ON // members are named Room_Motion_Sensor
if(triggeringItem.state == NULL) return; // we don't care about NULL
val room = triggeringItem.name.split("_").get(0)
val control = LightMotionControls.findFirst[ ctrl | ctrl.name == room + "_Motion_Control" ]
if(control.state == OFF) return; // ignore the update if control is OFF
// Get the values and associated Items
val timer = timers.get(triggeringItem.name)
val level = LightMotionLevels.members.findFirst[ ll | ll.name == room + "_" + HouseMode.state + "_Level" ].state as Number
val timoutMins = (LightMotionTimouts.members.findFirst[ to | to.name == room + "_" + HouseMode.state + "_Timeout" ].state as Number).intValue
val virtual = MotionLightsVirtual.members.findFirst[ v | v.name == room + "_Light_Virtual" ]
val dimLevel = LightMotionDims.members.findFirst[ dim | dim.name == room + "_Dim" ].state as Number
// Timer is already running
if(timer !== null) {
virtual.sendCommand(level) // undo the dim if necessary
timer.reschedule(timoutMins) // goes off timeoutMins minutes after the last time the motion sensor detects motion
// No Timer was running
else {
virtual.sendCommand(level) // turn on the light
// Create a timer to dimm then turn off the light
timer.put(triggeringItem.name, createTimer(now.plusMinutes(timeoutMins), [ |
// if already dimmed then turn off
if(virtual.state == dimLevel) {
virtual.sendCommand(OFF)
timers.put(triggeringItem.name, null) // clear the timer
// dim the light and reset the timer for another minute
else {
timers.get(triggeringItem.name).reschedule(1)
rule "Disable motion control if light changed by switch"
Member of Lights changed
if(triggeringItem.state != virtual.state) {
virtual.postUpdate(triggeringItem.state) // we don't want this to be treated as a new command
control.sendCommand(OFF) // disable the motion sensor control of the light
val int disabledTime = if(triggeringItem.state == 0) 10 else 60
val timer = ctrlTimers.get(triggeringItem.name)
if(timer !== null){
timer.reschedule(now.plusMinutes(disabledTime))
else {
ctrlTimers.put(triggeringItem.name, createTimer(now.plusMinutes(disabledTime), [ |
control.sendCommand(ON)
ctrlTimers.put(triggeringItem.name, null)
rule "Motion control resumed"
Member of LightMotionControls received command ON
val motion = LightMotionSenors.members.findFirst[ m | m.name == room + "_Motion_Sensor" ]
val light = Lights.members.findFirst[ l | l.name == room + "_Motion_Light" ]
if(timers.get(motion.name) !== null || light.state == 0) return; // a timer is already set to handle the light or the light is already off
if(light.state == dimLevel) return; // Light is already at the dim level
timers.put(motion.name, createTimer(now.plusMinutes(1), [ |
if(triggeringItem.state == OFF) virtual.sendCommand(OFF)
timers.put(motion.name, null)
With the above rules you just need to add your Items to the proper Group, named following the format above (see Associated Items DP) and you never have to touch your Rules to add new lights/motion sensors. Also note that there is no duplicated code. The Timer is created exactly in one place.
As I mentioned before, to get the immediate OFF at night, set the Bathroom_night_Level to 0.
One advantage of putting all of this data into Items instead of global vals is you can adjust them on your sitemap instead of having them hard coded in your rules. You will want to use persistence on these Items though.
I tried to stick to the same behavior that you already have but make the rules work for all your rooms, not just the one room. You never want to have to copy and paste code.
And for the record, I’ve posted this elsewhere before but here it is again, my lighting rules:
val logName = "lights"
// Theory of operation: Turn off the light that are members of gLights_OFF_<TOD> and
// then turn on the lights that are members of gLights_ON_<TOD>. Reset the overrides.
rule "Set lights based on Time of Day"
Item vTimeOfDay changed
// reset overrides
gLights_WEATHER_OVERRIDE.postUpdate(OFF)
val offGroupName = "gLights_OFF_"+vTimeOfDay.state.toString
val onGroupName = "gLights_ON_"+vTimeOfDay.state.toString
logInfo(logName, "Turning off lights for " + offGroupName)
val GroupItem offItems = gLights_OFF.members.filter[ g | g.name == offGroupName ].head as GroupItem
offItems.members.filter[ l | l.state != OFF ].forEach[ l | l.sendCommand(OFF) ]
logInfo(logName, "Turning on lights for " + onGroupName)
val GroupItem onItems = gLights_ON.members.filter[ g| g.name == onGroupName ].head as GroupItem
onItems.members.filter[ l | l.state != ON].forEach[ l | l.sendCommand(ON) ]
// Thoery of operation: If it is day time, turn on/off the weather lights when cloudy conditions
// change. Trigger the rule when it first becomes day so we can apply cloudy to lights then as well.
rule "Turn on lights when it is cloudy"
Item vIsCloudy changed or
// We only care about daytime and vIsCloudy isn't NULL
if(vTimeOfDay.state != "DAY" || vIsCloudy.state == NULL) return;
// give the side effects of time of day time to complete
if(triggeringItem.name == "vTimeOfDay") Thread::sleep(500)
logInfo(logName, "It is " + vTimeOfDay.state.toString + " and cloudy changed: " + vIsCloudy.state.toString +", adjusting lighting")
// Apply the cloudy state to all the lights in the weather group
gLights_ON_WEATHER.members.forEach[ l |
val overrideName = l.name+"_Override"
val override = gLights_WEATHER_OVERRIDE.members.findFirst[ o | o.name == overrideName ] as SwitchItem
if(override.state != ON && l.state != vIsCloudy.state) l.sendCommand(vIsCloudy.state as OnOffType)
if(override.state == ON) logInfo(logName, l.name + " is overridden")
// Theory of operation: any change in the relevant lights that occur more than five seconds after
// the change to DAY or after a change caused by cloudy is an override
rule "Watch for overrides"
Member of gLights_ON_DAY changed
// wait a minute before reacting after vTimeOfDay changes, ignore all other times of day
if(vTimeOfDay.state != "DAY" || vTimeOfDay.lastUpdate("mapdb").isAfter(now.minusMinutes(1).millis)) return;
// Assume any change to a light that occurs more than n seconds after time of day or cloudy is a manual override
val n = 5
val causedByClouds = vIsCloudy.lastUpdate("mapdb").isAfter(now.minusSeconds(n).millis)
val causedByTime = vTimeOfDay.lastUpdate("mapdb").isAfter(now.minusSeconds(n).millis)
if(!causedByClouds && !causedByTime) {
logInfo(logName, "Manual light trigger detected, overriding cloudy control for " + triggeringItem.name)
postUpdate(triggeringItem.name+"_Override", "ON")
