Hi
I want to modify from (editable) to (not editable) an item on the openhab panel.
can you help me?
If you want to inhibit editing of your HABPanel UI, you can set that on PaperUI
You can inhibit the editing of your complete Habpanel setup only!
I tried it
from where?
From here i can inhibit but everytime i must enter in the configuration of the item.
I want e bottom to control it
As this is not a tutorial, I’ve moved this topic to a more appropirate category.
