How to add a Roomba J7
OH version is 4.0.0
lunix Ubuntu 18.04
Hi community,
I would like to know if anyone has been able to add the Roomba J715840 to their openHab server.
Best
Have you tried the binding? iRobot - Bindings | openHAB
It helps us a whole lot if you explain what you’ve actually already tried.
Hi, thanks for the anwser but I tried it and I have the message bellow
2023-11-10 12:29:14.743 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘192.168.77.122’. Next attempt in 10000ms
2023-11-10 12:29:14.745 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘192.168.77.122’ with clientid A4C6BD3A47CE46C9873BF81586800B58
I try to use this method GitHub - koalazak/rest980: REST interface to control your iRobot Roomba 980 via local server on your lan.
but I not able to connect to my J7
Best
That ornament means you don’t have the binding configured correctly. Looking at the dice the configuration is quite involved.
What does MQTT have to do with anything?
That’s going to require using the HTTP binding. Configs?
