Please give step by step instructions on setting up a background image for HABpanel.
Writing URL into given setting is not working.
I saved my image manually in etc/openhab2/html and tried to access it “http://myPiaddress:8080/static/home.jpg ” , even this didn’t work.
I have no idea how to work with CSS and where to save that file .
Please help
Regards
becksen
(Becksen)
December 30, 2018, 3:52pm
2
I have the same issue.
Does anybody has suggestion?
Thanks.
ysc
(Yannick Schaus)
December 30, 2018, 9:15pm
3
try a server relative URL i.e. /static/home.jpg (without the protocol, host and port).
becksen
(Becksen)
December 31, 2018, 4:58pm
4
Hi ysc,
I found a solution https://community.openhab.org/t/display-local-images/2592/9
Copy the files to conf/icons/classic and address them via the following URL:
url="http://serverip:8080/icon/filename.png" ;
Works fine for me. Important the spelling of the url path. “icon” is correct although you store it on /icons/classic on the filesystem.
Best regards.
… and the resource in \conf\html
where to put the file is what hung me up for a few moments
jamac
(jamac)
January 14, 2019, 8:47pm
6
I’m new to OH2 and am struggling with this too. I’m running OH2 on an Openhabian RPi 3 B+ with Habpanel on an iPad as my front end.
My problem is that i can’t seem to load a background image via Habpanel’s settings page. I suspect I’m not specifying the image path correctly.
I’ve placed the jpg image in openHab-conf/icons/classic but can’t seem display it in Habpanel.
I’ve tried:
http://[ipaddress]:8080/openHAB-conf/icons/classic/image.jpg
http://[ipaddress]/openHAB-conf/icons/classic/image.jpg
What am i doing wrong???
jamac
(jamac)
January 17, 2019, 9:15pm
7
Ok. So after a lot of trial and error the following worked for me.
Place the jpg in http://[ipaddress]/openHAB-conf/html
In Habpanel’s panel settings page, set the ‘background image’ setting to /static/image.jpg
