How to add configuration for Z-Wave device FIBARO WALL PLUG FGWPE/F-102
I wasn’t paying attention and bought a Fibaro Wall Plug, FGPE/F-102.
https://manual.zwave.eu/backend/make.php?lang=DE&sku=FGWPE/F-102&cert=ZC10-18025991
And this device isn’t recognized by openhab, z-wave binding. I already have an older, similar FGWP102 wall switch model, and that works great.
I recently installed the stable version of Openhab, openhab addons 4.2.3. In the jar file I find XML files for FGWP102.
root@kuzma:~/wave# find . | grep -i fgw | grep 102
./OH-INF/thing/fibaro/fgwp102_2_1.xml
./OH-INF/thing/fibaro/fgwp102_3_2.xml
I thought maybe the devices are similar in functionality and I can copy and adjust the existing file so that it is recognized by the openhab z-wave binding? I won’t use it that much, just for switching lights on/off. I actually just need the switch channel only. I though I can manipulate jar file and add new xml file.
How is the suitable for device configuration file identified?
Thanks for any advices.
Zwave devices are identified by hex numbers MFG:TYPE:ID:Version. Could review this post on options.
The preferred option (to be a good community member) is to add the device to the ZW DB, so others will be able to use the device. That said as temporary option you could modify the jar.
