How to add Regex Filter to log4j2.xml
Hey,
How to add regex filter to new filesystem for logging conf?
I found on internet something like this:
<RegexFilter regex=".* modbus_reset_switch .*" onMatch="DENY" onMismatch="ACCEPT"/>
but it is not working.
What I try to do is filter logs to be without:
2020-12-05 02:02:37.878 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'modbus_reset_switch' received command ON
If you do not want…
org.eclipse.smarthome.event.ItemCommandEvent
… in your events.log, then set the log level to WARN or OFF from the Karaf console…
log:set WARN org.eclipse.smarthome.event.ItemCommandEvent
You can find more detail in the documentation…
I dont want to turn everything off. I only want to disable this particular log entry. Only for modbus_reset_switch
In your regex you have spaces around the item name, perhaps that is the reason it does not match?
I checked it, and nothing.
First I got without spaces, but in here they have spaces:
@Kamil_Matuszczak Did you figure this out? Need to filter out some event-spam
[EDIT] Found it here
and run systemctl restart openhab.service
