The only minus for selection instead of Switch is, that you do not see the current status. Is there a way to bring (50) and the red selected status back?
I don’t understand, why don’t you see the current status? it’s the selected item that is the current status , if the item is updated from another source the selection also updates, atleast it does for me.
@lfs_alp5
Yes, your are right. But to see this, I have to go to the submenue.
I use mappings for my roller shutters and I want ot see the current status on one page. With selection I have to enter every selection menue to see current status of every roller shutter by its own.
The reason you can’t use selection item on the items you’ve configured is because it’s not equal to the actual state of the items. As I can see from your sitemap the item values are “100”, which is not a choice on your Switch mappings and therefore won’t be selected, this would also fail on a Selection item.
In short (withouth seeing your configuration), your sitemap configuration and mappings seem incorrect.
Edit: Just wanna add, I see no reason why you can’t have that list with a selection item as long as the sitemap is configured correctly.
@lfs_alp5
Please take a look at my first screenshot
If I use selection, I see nothing about the current state, only an arrow which leads me to the submenue with the selection. Good will be to have minimum the value of the item (50) in the main screen
