How to analyse openhab log error message
Hello all,
How can you guys understand these long errors , How can I find the related items, I find these error messages unreadable and just an other crash :sweat_smile:
2020-09-19 02:45:00.877 [ERROR] [org.quartz.core.JobRunShell         ] - Job DEFAULT.Timer 17 2020-09-19T02:20:00.828+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
  org.eclipse.xtext.xbase.impl.XIfExpressionImpl@246c32 (conditionalExpression: false)
} ] threw an unhandled Exception:
	at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:65) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:954) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:235) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:857) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:231) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1205) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1135) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:237) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:469) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:255) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
	at com.sun.proxy.$Proxy349.apply(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
2020-09-19 02:45:00.923 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.Timer 17 2020-09-19T02:20:00.828+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
	at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
Caused by: java.lang.NullPointerException
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
	... 1 more
Generally, the interesting stuff is in the first few lines.
This tells you “who” is complaining.
In this case, it is the ‘quartz’ scheduler that openHAB uses for all timing purposes.
You’re not expected to know that, but a quick search of this forum will soon show that.
Alright, so its some kind of timer issue. As it happens these are not very easy to diagnose for various reasons.
That’s not very helpful.
But just by recognising the pattern of this message, as frequently reported in this forum, we can say that is about a timer that was created by a rule. By createTimer() in a DSL rule. But you cannot tell which rule.
It’s failed when it has come time to run the code.
This part is a little more helpful.
It’s a kind of skeleton that the timer code has run before it hit the error. Often there’s more lines of skeleton code, giving a better hint.
So to narrow down the source, you’re hunting through your rules looking for something like
createTimer ( ... |  [
    if ( something ) {
This is where most timer issues end up, which is why they are difficult to diagnose.
Something evaluated to null. Cannot tell what.
Some variable turned to be null when the timer code tried to use it.
For example,
if (someItem.state as Number == 22)
will blow up if the Item has a state of NULL at the time, because that can’t be evaluated to a number.
You could write code to deal with that more gracefully.
Sometimes it is about context - the timer code trying to use some variable that gets defined in some other part of the rule or elsewhere. Except it isn’t defined when the timer code asks for it.
“Context” leads us neatly to …
Always be aware of this issue when editing rules files.
@rossko57 Thanks a lot , that was helpful
