Hi all, i may have a solution to our “split brain” issue going on here. There are a number of changes in the works right now, but a big one will be a push i’m doing tomorrow that will hopefully ensure our cloud code only allows 1 connection from a authorized UUID to try and connect. The issue i think we have now is that the underlying socket.io retry logic tries a couple of times to reconnect in the background, while those happen serially on the client, due to load balancing, DB calls, redis calls, etc., the cloud service can actually be processing those in parallel which means a connection that the client gave up on, may finish after a good connection is made, which then overwrites the DB with the wrong server address and we no longer know how to route proxy connections to it.
We also have some changes to the cloud addon to connect more gracefully that we will try and get into the next 3.4.x release as well as 4.0
