I am using Alexa from openhab 4.1 which works so far. I also can call a routine directly when speaking to Alexa. Now I would like to start an existing routine directly from OH.
Which channel (item) I need to use and what is the command looks like?
which is only visible, if you select Show advanced
Then you simple send the command, you would tell Alexa to start the routine, to the item - in my case: Licht aus:
Echo_Livingroom_Routine.sendCommand(‘Licht aus’)
