I have a script file, say, 100_rules.py with rules and functions, a function, say, getColorTable() can be called from one of the rules, send parameters, receive returned data, works.
Now from a second script file, 200_rules.py: how can I reach the function in the first file?
They don’t seem to share a namespace and ‘see’ each other. Is there anything like scriptName.functionName() to reach the function in the other script file?
From a script, you cannot access a function in another script. However, you can put the function into a module and import it into the script. Just copying your script into /automation/lib/python/personal/
to make it a module will probably not be enough, since the scope of modules is different than scripts. You can find some more detail here…
If you need more, just ask!
