How can I detect when a ZWAVE switch has been turned on again. This is a simple Leviton DZ15S ON/OFF switch. When the switch is already ON and the ON button is pressed again I get that status in the LOG. How can I capture and use that in a Rule. I what to detect if the ON switch is being pressed multiple times.
This is the log output when the ON button is pressed and the device is already ON:
13:23:21.048 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - lastTransaction null
13:23:21.051 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 22: Application Command Request (ALIVE:DONE)
13:23:21.054 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 22: resetResendCount initComplete=true isDead=false
13:23:21.057 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 22: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 0
13:23:21.060 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 22: SECURITY not supported
13:23:21.062 [DEBUG] [otocol.commandclass.ZWaveCommandClass] - NODE 22: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
13:23:21.065 [DEBUG] [ndclass.ZWaveBinarySwitchCommandClass] - NODE 22: Switch Binary report, value = 255
13:23:21.068 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 22: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
13:23:21.072 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 22: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_BINARY, value=255
13:23:21.075 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 22: Updating channel state zwave:device:3030737e:node22:switch_binary to ON [OnOffType]
13:23:21.080 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 22: Commands processed 1.
13:23:21.084 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 22: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f17303.
13:23:21.087 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 22: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f17303.
13:23:21.090 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 22: notifyTransactionResponse TID:709 DONE
13:23:21.094 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 22: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
13:23:21.097 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
13:23:21.099 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
13:23:21.102 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
13:23:21.107 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
