First, I have really searched. But Configuration and Parameters are word that are to often used.
I want to change the parameters by rules and I can’t find how. Can anybody help me find an example how to change those parameters by rule?
In detail, I would like to change the behavior of the physical input of a dimmer to not go “ON/OFF” but to go “20%/OFF”. If any experience, I would be grateful.
I am talking about this configuration parameters that are shown in Homegear command line:
root@raspberrypi:/home/pi# homegear -r
> families select 0
Family 0> peers select 35
Family 0 - peer 35> config print
MASTER
Channel: 3
[TRANSMIT_TRY_MAX]: 06
[STATUSINFO_RANDOM]: 01
[AES_ACTIVE]: 00
[POWERUP_ACTION]: 00
[LOGIC_COMBINATION]: 00
[STATUSINFO_MINDELAY]: 04
Channel: 2
[AES_ACTIVE]: 00
Channel: 1
[AES_ACTIVE]: 00
[LOGIC_COMBINATION]: 01
Channel: 0
[ROAMING]: 00
[POLLING_INTERVAL]: 3c
[CONF_BUTTON_TIME]: ff
[INTERNAL_KEYS_VISIBLE]: 01
[POLLING]: 00
[LOCAL_RESET_DISABLE]: 00
VALUES
Channel: 3
[RAMP_TIME]: a0
[RAMP_STOP]: 00
[WORKING]: 00
[ERROR_OVERLOAD]: 00
[LEVEL]: 00
[ERROR_OVERHEAT]: 00
[OLD_LEVEL]: 00
[DIRECTION]: 00
[INHIBIT]: 00
[ERROR_REDUCED]: 00
[ON_TIME]: 00
[INSTALL_TEST]: 00
[LEVEL_REAL]: 00
Channel: 2
[RAMP_TIME]: a0
[RAMP_STOP]: 00
[WORKING]: 00
[LEVEL]: 00
[OLD_LEVEL]: 00
[DIRECTION]: 00
[INHIBIT]: 00
[ERROR_REDUCED]: 00
[ON_TIME]: 00
[INSTALL_TEST]: 00
[LEVEL_REAL]: 00
Channel: 1
[RAMP_TIME]: a0
[RAMP_STOP]: 00
[WORKING]: 00
[LEVEL]: 00
[OLD_LEVEL]: 00
[DIRECTION]: 00
[INHIBIT]: 00
[ERROR_REDUCED]: 00
[ON_TIME]: 00
[INSTALL_TEST]: 00
[LEVEL_REAL]: 00
Channel: 0
[DEVICE_IN_BOOTLOADER]: 00
[CENTRAL_ADDRESS_SPOOFED]: 00
[RSSI_PEER]: 00
[AES_KEY]: 00
[CONFIG_PENDING]: 00
[LAST_PACKET_RECEIVED]: 5e 41 51 43
[DUTYCYCLE]: 00
[UPDATE_PENDING]: 00
[RSSI_DEVICE]: 48
[STICKY_UNREACH]: 01
[UNREACH]: 00
LINK
Channel: 3
Address: 0x33a752
Remote channel: 1
[UI_HINT]: 00
[SHORT_RAMP_START_STEP]: 0a
[SHORT_RAMPON_TIME]: 05
[SHORT_ONDELAY_TIME]: 00
[SHORT_OFF_TIME_MODE]: 00
[SHORT_OFF_TIME]: ff
[SHORT_OFF_LEVEL]: 00
[SHORT_OFFDELAY_NEWTIME]: 04
[SHORT_OFFDELAY_BLINK]: 01
[SHORT_JT_OFFDELAY]: 05
[SHORT_ELSE_JT_RAMPOFF]: 06
[SHORT_RAMPOFF_TIME]: 05
[SHORT_ELSE_ON_TIME_MODE]: 00
[SHORT_ELSE_JT_ONDELAY]: 02
[SHORT_ELSE_JT_ON]: 04
[SHORT_ELSE_JT_OFF]: 01
[SHORT_ELSE_OFF_TIME_MODE]: 00
[SHORT_ELSE_ACTION_TYPE]: 00
[SHORT_ELSE_JT_OFFDELAY]: 05
[SHORT_DIM_STEP]: 0a
[SHORT_DIM_MAX_LEVEL]: c8
[SHORT_ON_MIN_LEVEL]: 14
[SHORT_CT_RAMPON]: 00
[SHORT_CT_RAMPOFF]: 00
[SHORT_CT_ONDELAY]: 00
[SHORT_CT_ON]: 00
[SHORT_ELSE_JT_RAMPON]: 03
[SHORT_DIM_MIN_LEVEL]: 00
[SHORT_CT_OFFDELAY]: 00
[SHORT_ON_LEVEL]: c8
[SHORT_COND_VALUE_LO]: 32
[SHORT_COND_VALUE_HI]: 64
[LONG_ELSE_JT_RAMPON]: 03
[SHORT_JT_RAMPON]: 03
[LONG_ELSE_JT_ON]: 04
[SHORT_ON_TIME]: ff
[LONG_ELSE_JT_ONDELAY]: 02
[SHORT_JT_ON]: 04
[LONG_ELSE_JT_OFFDELAY]: 05
[LONG_DIM_MIN_LEVEL]: 00
[LONG_OFF_TIME]: ff
[LONG_ELSE_OFF_TIME_MODE]: 00
[LONG_ON_LEVEL_PRIO]: 00
[LONG_ELSE_ON_TIME_MODE]: 00
[LONG_OFFDELAY_OLDTIME]: 04
[LONG_JT_RAMPON]: 03
[LONG_RAMPON_TIME]: 05
[SHORT_ON_LEVEL_PRIO]: 00
[LONG_COND_VALUE_LO]: 32
[LONG_CT_OFFDELAY]: 00
[SHORT_OFFDELAY_STEP]: 0a
[LONG_OFFDELAY_TIME]: 00
[SHORT_OFFDELAY_TIME]: 00
[SHORT_CT_OFF]: 00
[LONG_DIM_STEP]: 0a
[LONG_ELSE_MULTIEXECUTE]: 01
[LONG_COND_VALUE_HI]: 64
[LONG_CT_ON]: 00
[SHORT_JT_ONDELAY]: 02
[LONG_MULTIEXECUTE]: 00
[LONG_ELSE_ACTION_TYPE]: 00
[SHORT_OFFDELAY_OLDTIME]: 04
[LONG_DIM_MAX_LEVEL]: c8
[LONG_ACTION_TYPE]: 00
[LONG_ELSE_JT_OFF]: 01
[LONG_CT_ONDELAY]: 00
[LONG_CT_RAMPOFF]: 00
[LONG_JT_OFF]: 01
[LONG_JT_OFFDELAY]: 05
[LONG_OFFDELAY_STEP]: 0a
[LONG_RAMP_START_STEP]: 0a
[LONG_ON_TIME_MODE]: 00
[SHORT_ON_TIME_MODE]: 00
[LONG_JT_ON]: 04
[LONG_ON_TIME]: ff
[LONG_OFF_LEVEL]: 00
[LONG_JT_RAMPOFF]: 06
[LONG_OFFDELAY_BLINK]: 01
[SHORT_ACTION_TYPE]: 00
[LONG_ON_LEVEL]: c8
[LONG_OFFDELAY_NEWTIME]: 04
[SHORT_JT_OFF]: 01
[LONG_CT_OFF]: 00
[LONG_OFF_TIME_MODE]: 00
[SHORT_JT_RAMPOFF]: 06
[LONG_JT_ONDELAY]: 02
[LONG_ONDELAY_MODE]: 00
[LONG_ELSE_JT_RAMPOFF]: 06
[LONG_ONDELAY_TIME]: 00
[SHORT_ONDELAY_MODE]: 00
[LONG_CT_RAMPON]: 00
[LONG_ON_MIN_LEVEL]: 14
[LONG_RAMPOFF_TIME]: 05
Channel: 2
Address: 0x33a752
Remote channel: 1
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_ON_TIME]: ff
[SHORT_JT_ON]: 04
[LONG_OFF_TIME]: ff
[SHORT_CT_OFF]: 00
[LONG_DIM_STEP]: 0a
[LONG_CT_ON]: 00
[LONG_JT_OFF]: 01
[LONG_JT_ON]: 04
[LONG_ON_TIME]: ff
[LONG_ON_LEVEL]: c8
[SHORT_JT_OFF]: 01
[LONG_CT_OFF]: 00
Channel: 1
Address: 0x33a752
Remote channel: 1
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_ON_TIME]: ff
[SHORT_JT_ON]: 04
[LONG_OFF_TIME]: ff
[SHORT_CT_OFF]: 00
[LONG_DIM_STEP]: 0a
[LONG_CT_ON]: 00
[LONG_MULTIEXECUTE]: 01
[LONG_ACTION_TYPE]: 06
[LONG_JT_OFF]: 01
[LONG_JT_ON]: 04
[LONG_ON_TIME]: ff
[SHORT_ACTION_TYPE]: 01
[LONG_ON_LEVEL]: c8
[SHORT_JT_OFF]: 01
[LONG_CT_OFF]: 00
