How to check Status remote server, start and stop too
Hello
with the command
ipmitool -I lanplus -H 10.18.14.200 -U ADMIN -P password chassis power status
got the feedack Chassis Power is on
ipmitool -I lanplus -H 10.18.14.200 -U ADMIN -P password chassis power on
it will start/boot the remote Server
button turn yellow and after 5 Minutes be green (it is the time all the VM needs to boot too)
ipmitool -I lanplus -H 10.18.14.200 -U ADMIN -P password chassis power soft
will gracefull shutdown the server (include all VM’s inside)
i wisch to have a the information and/or button to switch on or off
another button would be for a second server without the switch on/off function
how and where to start to do it?
Create a rule that uses e.g. executeCommandLine to execute a command. Then connect the rule to a button
any link to a information page or tutorial how to manage it?
i startet to crate the rule
if i switch a button is this a thing, trigger or item?
if the command
ipmitool -I lanplus -H 10.18.14.201 -U xxx -P xxx chassis power status
Chassis Power is off the button should be orange
Chassis Power is on the button should change to green
i created for all commands a exec:command:xxx too
