As I’m continuing my work on an Open Meteo binding, I’m starting to generate timeseries that are sent to the appropriate channels.
In the log, I see this kind of messages:
Item 'OpenMeteo_forecast_Outdoor_Temperature' shall process timeseries [Entry[timestamp=2024-02-22T00:00:00Z, state=9.877501 °C], Entry[timestamp=2024-02-22T01:00:00Z, state=9.9775 °C], Entry[timestamp=2024-02-22T02:00:00Z, state=10.627501 °C], ...
I believe this is then working fine, but I’m having a hard time figuring out what to do with that.
I thought that I could maybe graph the future temperature by creating a Chart page that would display the item linked to that channel.
MainUI created this definition for me:
label: Temperature
sidebar: true
slots:
dataZoom: []
grid:
- component: oh-chart-grid
config: {}
series:
- component: oh-time-series
gridIndex: 0
item: OpenMeteo_forecast_Outdoor_Temperature
type: line
xAxisIndex: 0
yAxisIndex: 0
xAxis:
- component: oh-time-axis
gridIndex: 0
yAxis:
- component: oh-value-axis
gridIndex: 0
But it doesn’t display anything which might be logical as the x axis only goes as far as today.
Looking at the various options, I figured that maybe I could use the offset to see the future, like this:
offsetAmount: -3
offsetUnit: day
As the documentation says the amount is subtracted from the value, I thought that a negative value would go in the future.
But this did not change a thing.
Then I reread the 4.1 announcement and saw that RRD4J does not support storing future values.
So I installed JDBC SQLite, configured it and changed the graph page to use jdbc
service: jdbc
Still to no avail, the graph is still empty.
I looked at the generated SQLite file, it stays empty which would actually explain why the graph is empty.
I also edited the persistence strategy to include forecast
on top of everyChange
but that did not make the persistence SQLite file grow.
How do I get my timeseries stored in the SQLite persistence file?
What did I miss?
