In my rule I have value from temperature sensor saved in String Item’s state. Value is retrieved from shell script via exec binding and looks like this (example): 24.6 (always rounded to one decimal, contains point).
How can I use this value in my if statement?
This does nothing:
if(MyStringItem.state > 30) {
# very hot
This throws “Could not cast…”
if((TempOut.state as Number) > 30) {
# very hot
if((TempOut.state as DecimalType) > 30) {
# very hot
This throws “Could not invoke method…”
if(Integer::parseInt(TempOut.state) > 30) {
# very hot
Not sure of the type. It is retrieved value from exec binding. Source of the value is shell command output.
Is there simpler documentation version then this xtend documentation? As far I understand OpenHAB rule scripts follow this syntax. As a non programmer I have trouble using official Xtend documentation.
You defined the type of your Item when you created it, you told us it was a String type.
Okay, no openHAB docs are going to tell what results you get from some external script.
The binding docs do tell you that whatever the results are, they are fed into a string type channel.
Nope. Best resource is this very forum and its search feature.
If you are not comfortable using Rules DSL, don’t use it. Jython and javascript are also popularly used as rules languages.
