I could not find any sample how to configure the light sensor of the Elaborated Networks Onewire Multi Sensor in the bms thing (bms seems the correct sensor - hopefully)
I am running OH 2.5 (2.5.11-1) and I am using a Multisensor with temperature, humidity and light.
All channels unless the light channels are working properly, I could see the illumination value, when checking the OW Server:
owget /family.address/S3-R1-A/illuminance : 395.304
But the defined thing doesn’t fill any information
"link": "http://raspi3.wilde13:8080/rest/items/OneWireMulti1Light",
"state": "NULL",
"stateDescription": {
"pattern": "%.1f",
"readOnly": false,
"options": []
"editable": false,
"type": "Number:Illuminance",
"name": "OneWireMulti1Light",
"label": "Illuminance",
"tags": [],
"groupNames": [
"g5Min"
The thing definition looks the following:
Thing bms owmulti1 “OW GA Multi1” [
id=“family.address”,
refresh=300,
temperaturesensor=“DS18B20”,
lightsensor=true
Channels:
Type temperature-por-res : temperature [
ignorepor=true,
resolution=“11”
Type humidity : humidity []
Type absolutehumidity : absolutehumidity []
Type dewpoint : dewpoint []
Type supplyvoltage : supplyvoltage []
Type light : light []
This works for all channels unless the light/radiation.
The item definition looks like
Number:Illuminance OneWireMulti1Light “Illuminance [%.1f]” (g5Min) { channel=“onewire:bms:owbridge:owmulti1:light” }
Does anybody have an idea what happened ?
And what I could do ?
Thanks in advance
Kolja
