I was not able, to get the power meter report for both nodes of the Qubino Flush 2 Relays (ZMNHBD2). I use this item configuration, but the I dont get both values:
Number Switch_Pool1_Power "Pool Licht - aktuell [%.1f W]"<energy> (gSP) {zwave="36:1:command=meter,meter_scale=E_W" } Number Switch_Pool2_Power "Pool Pumpe - aktuell [%.1f W]"<energy> (gSP) {zwave="36:2:command=meter,meter_scale=E_W" }
The controller is member of the two association groups Q1 power meter and Q2 power meter.
Can anybody help me? What am I doing wrong?
This is the xml-file of this node:
<node>
<deviceClass>
<basicDeviceClass>ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>BINARY_SWITCH</genericDeviceClass>
<specificDeviceClass>POWER_SWITCH_BINARY</specificDeviceClass>
</deviceClass>
<homeId>0xda84ec12</homeId>
<nodeId>36</nodeId>
<version>4</version>
<name>Schalter Pool Licht + Pumpe</name>
<location>Garten Stromkasten Pool-Elektrik</location>
<manufacturer>0x159</manufacturer>
<deviceId>0x51</deviceId>
<deviceType>0x2</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<healState>DONE @ 2016-06-27T16:10:51+0000</healState>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<nodeInformationFrame/>
<supportedCommandClasses>
<entry>
<commandClass>MANUFACTURER_SPECIFIC</commandClass>
<manufacturerSpecificCommandClass>
<version>1</version>
<instances>1</instances>
</manufacturerSpecificCommandClass>
</entry>
<entry>
<commandClass>VERSION</commandClass>
<versionCommandClass>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>4.5</protocolVersion>
<applicationVersion>1.2</applicationVersion>
</versionCommandClass>
</entry>
<entry>
<commandClass>ASSOCIATION</commandClass>
<associationCommandClass>
<configAssociations>
<entry>
<int>1</int>
<associationGroup>
<Index>1</Index>
<Nodes/>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<Index>2</Index>
<Nodes/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<Index>3</Index>
<Nodes/>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<Index>4</Index>
<Nodes>
<int>1</int>
</Nodes>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<Index>5</Index>
<Nodes/>
</associationGroup>
</entry>
<entry>
<int>6</int>
<associationGroup>
<Index>6</Index>
<Nodes/>
</associationGroup>
</entry>
<entry>
<int>7</int>
<associationGroup>
<Index>7</Index>
<Nodes>
<int>1</int>
</Nodes>
</associationGroup>
</entry>
<entry>
<int>8</int>
<associationGroup>
<Index>8</Index>
<Nodes/>
</associationGroup>
</entry>
</configAssociations>
<maxGroups>8</maxGroups>
</associationCommandClass>
</entry>
<entry>
<commandClass>SWITCH_ALL</commandClass>
<switchAllCommandClass>
<isGetSupported>true</isGetSupported>
<mode>SWITCH_ALL_INCLUDE_ON_OFF</mode>
</switchAllCommandClass>
</entry>
<entry>
<commandClass>METER</commandClass>
<meterCommandClass>
<version>3</version>
<meterType>ELECTRIC</meterType>
<meterScales>
<meterScale>E_W</meterScale>
<meterScale>E_KWh</meterScale>
</meterScales>
<canReset>true</canReset>
<isSupportRequestSupported>true</isSupportRequestSupported>
</meterCommandClass>
</entry>
<entry>
<commandClass>MULTI_INSTANCE</commandClass>
<multiInstanceCommandClass>
<version>2</version>
<endpoints>
<entry>
<int>1</int>
<endPoint>
<deviceClass>
</deviceClass>
<endpointId>1</endpointId>
<entry>
<libraryType>LIB_UNKNOWN</libraryType>
</entry>
<entry>
<configAssociations/>
<maxGroups>4</maxGroups>
</entry>
<entry>
</entry>
<entry>
<meterCommandClass>
<meterScales>
</meterScales>
</entry>
<entry>
<commandClass>SWITCH_BINARY</commandClass>
<binarySwitchCommandClass>
</binarySwitchCommandClass>
</entry>
<entry>
<commandClass>BASIC</commandClass>
<basicCommandClass>
<version>0</version>
<instances>0</instances>
</basicCommandClass>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
<entry>
<int>2</int>
<endPoint>
<deviceClass>
</deviceClass>
<endpointId>2</endpointId>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<meterCommandClass>
<meterScales>
</meterScales>
</entry>
<entry>
</entry>
<entry>
<basicCommandClass>
</entry>
</endPoint>
</entry>
</endpoints>
<endpointsAreTheSameDeviceClass>true</endpointsAreTheSameDeviceClass>
</multiInstanceCommandClass>
</entry>
<entry>
</entry>
<entry>
<commandClass>NO_OPERATION</commandClass>
<noOperationCommandClass>
</noOperationCommandClass>
</entry>
<entry>
<basicCommandClass>
</entry>
<entry>
<commandClass>CONFIGURATION</commandClass>
<configurationCommandClass>
<configParameters>
<entry>
<int>64</int>
<configurationParameter>
<index>64</index>
<size>1</size>
<value>0</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>1</int>
<index>1</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>2</int>
<index>2</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>40</int>
<index>40</index>
<size>1</size>
<value>50</value>
</entry>
<entry>
<int>41</int>
<index>41</index>
<size>1</size>
<value>50</value>
</entry>
<entry>
<int>10</int>
<index>10</index>
<size>2</size>
<value>255</value>
</entry>
<entry>
<int>42</int>
<index>42</index>
<size>2</size>
<value>60</value>
</entry>
<entry>
<int>11</int>
<index>11</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>43</int>
<index>43</index>
<size>2</size>
<value>60</value>
</entry>
<entry>
<int>12</int>
<index>12</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>13</int>
<index>13</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>14</int>
<index>14</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>110</int>
<index>110</index>
<size>2</size>
<value>32536</value>
</entry>
<entry>
<int>15</int>
<index>15</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>120</int>
<index>120</index>
<size>1</size>
<value>5</value>
</entry>
<entry>
<int>30</int>
<index>30</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>63</int>
<index>63</index>
<size>1</size>
<value>0</value>
</entry>
</configParameters>
</configurationCommandClass>
</entry>
<nodeNeighbors>
<int>18</int>
<int>21</int>
<int>32</int>
</nodeNeighbors>
<lastSent>2016-06-27 16:10:45.595 UTC</lastSent>
<lastReceived>2016-06-27 16:10:50.771 UTC</lastReceived>
</node>
