I have some Xiaomi Aqara all in one sensors (temperature, humidity and pressure) here. Also A Zigbee stick CC2531 which I flashed with different firmware as one can find in several tutorials on the web.
I run OpenHAB 2 on a raspPi 3B+.
In OpenHAB 2 now I added the Zigbee binding using Paper UI interface.
If I use Paper UI as well to add the things and items I can get everything working - but I want to do this using *.things and *.items files to get a better overview.
This is my *.things file:
Bridge zigbee:coordinator_cc2531:00112233 "Zigbee coordinator" @ "Livingroom" [zigbee_macaddress="00158e00022dbg01", zigbee_port="/dev/ttyACM0"]
Thing device 00158e00022dbg01 "Weather all in one" @ "Livingroom"
Under Paper UI Things I can see the āZigbee coordinatorā which is online.
I also see the āWeather all in oneā thing but it shows āUNINITIALIZEDā.
If I click on the thing I get some furter message āHANDLER_CONFIGURATION_PENDINGā.
I look in the OpenHAB docu which says that the thing is missing some parameters.
The problem I have is that I do not really know how to configure the thing correctly.
After āThing deviceā I added the MAC Adress of the Zigbee stick but I know it is wrong.
Can someone assist me how to get the correct configuration string?
Thanks a lotā¦
