Hi ,
I am new to HAB, so please help me or suggest how to Connect to MiOS gateway controller.
Let me know what all the steps that needs to be carried out.
With regards,
Vikram
Hi ,
With regards,
Vikram
You will find most of the information you need nere:
https://docs.openhab.org/v2.2/addons/bindings/mios1/readme.html
Basically, you need to install the binding using paperui and then enter the IP address of your Vera controller in /etc/openhab2/services/mios.cfg.
You use the MiOS item generator to pull the configuration from your Vera and create an items filse that you save in /etc/openhab2/items.
