Hi i setup tv (tvVolume) and also try add speaker to GH. They are successfully shown in google home (with correct tv/speaker icons) but how to increase/decrease volume by voice? For example when i connect my “speaker” from Broadlink app i say “Ok google increase sound by 5 on MyDevice” and all works but with OH 3 it docent work, any help?
Does the assistant respond with a confirmation?
If yes, does the value in openhab afterwards just not change?
i try differed voice commands and this “set volume by five on myTV” work (but not 100% and most of try it change google home mini volume), but i still don’t understand why “Ok google increase sound by 5 on MyDevice” command doesn’t work. What voice commands you use to change volume on sound devices like tv and speaker?
The docs only state something like:
Make the TV much louder will set a higher number of steps than Make the TV a tiny bit louder.
or setting volume to an absolute level similar to your first example:
Set volume to 5
There seems to be no way of stating the relative increase/decrease with a number.
