I am trying to control a dimmer channel via a switch in Habpanel, but this doe not seem to work.
When connecting both a slider and a switch to the dimmer channel, pressing the switch affect the slider setting in the correct way ( max or min ) however the lamp is not controlled. Using the slider works.
Behaviour is the same for MQTT and ZWAVE
What is the preferred way to use a dimmer as a switch ?
(Assuming the devices do not have an on/off or power channel)
When in Habpanel a switch is linked to it, the switch can toggle the lamp. When both a switch and a dimmer are linked to it, the the switch affects the dim slider, but lamp on or off does not work.
Using the slider does affects the lamp.
