My first post here, hope you can help me out and make me a little wiser and happier.
I bought a aeotec Z-stick gen5 and a Fibaro FGS-222 dual relay switch.
My intention was to use the fibaro to connect two outdoor motion detectors, and get the state of the motion detection into openHAB. Then I want to connect two lights to the fibaro (1 normal outdoor lamp, and 1 lamppost).
I want to switch both lights on during set hours when movement is detected, and also switch the lamppost on during set hours.
Hope you understand what I am trying to build, this is my first openHAB project! I searched to find the answer on my following questions, but couldnât find any.
Can you tell me if what i want is possible? Can I read the inputs of the fibaro, and control the outputs, using openHAB?
If this is possible, can you help me how to read the inputs, and set the outputs?
I think I should configure the correct zwave commands/parameters in the openhab default.items file? I couldnât find any example of these commands/parameters.
I will continue my search, and in the meantime I hope someone will help me here!
The fibaro is working now, if input1 gets powered, relay1 will be closed. Thats nice if openHAB is down, but I want some more control.
Is it possible to override the state of the relay? Or can I somehow catch the command coming from input going to the relay?
Itâs unclear what youâre looking for, please explain better.
Do you want openhab to just switch lights during certain hours, but motion detectors fire all day long ?
If you connect the motion detectors like switches (to inputs I1 and I2), then theyâll turn on the lights on when they detect and back off when they time out.
But thatâs just as they would do if there wasnât any relay inbetween. The only difference would be that you get the switching info into openhab so you see light state and detector events there, and you could also use the OH GUI to switch lights manually.
Generally speaking, local switching takes precedence, you cannot âcatchâ the electric command.
If itâs about switching during certain hours only, then thereâs different possibilities:
write a rule that triggers on input state changes (i.e. motion detector firing) and turn lamps back off during times when you donât want them to turn on.
(you need two items if you attach the lights to O1 and O2 outputs:
Switch OutdoorLamp âoutdoor lamp on FGS-222 out port 1â {zwave=â2:1â}
Switch LampPost âlamp post on FGS-222 out port 2â {zwave=â2:2â}
buy a zwave motion detector instead locally attaching yours, plus use the rule from 1)
you could attach your detector to FGS-222 input I1 and BOTH lamps to output O2, so you have a blind output O1, plus use the rule from 1). But then you obviously cannot switch the lights independently.
Sorry if I was not clear about what I am looking for, I will try to explain it again.
But if I read your answer, I think what I want is not possible, or not the correct way.
-During daytime (when there is enough daylight), I want both the relays (output1 and output2), to stay turned off.
-During nighttime (when it is dark), I want output 1 to be turned on from sunset till midnight.
-When it is dark, and motion is detected (using the motion detector on input 1), i want both outputs to turn on, and stay on for 5 minutes.
So the following happens:
when there is daylight, the outputs never switch on
when it is dark, and before midnight, output1 will be on
when it is dark, and before midnight, and motion is detected, output2 will turn on
when it is dark, and before midnight, and motion is detected, both outputs will turn on
I considered buying a zwave motion detector, but found a lot of posts complaining about these detectors. So I decided to use a normal outdoor motion detector, and connect it to an zwave input.
If I want to use your possibility 1, will this rule be âfastâ enough? Will the light be switched off in time, or will it blink for a short time?
zwave motion detectors are fine in general (and a better idea than your construction), just the Aeotec one on battery is a bad idea. But as you apparently have mains power where you want to place it, it has the option to power it from mains, too, then itâs working well.
As you want a time based logic that only the OH server can implement, you need a second zwave device, so logically, you have one sensor and one (or more) actor and the OH server inbetween to decide whether and when to forward the signal.
So either get a zwave motion detector or another zwave relay (or binary sensor) and attach your classic motion detector there.
My proposal #3 virtually splits your (single) relay into two halves, a sensor and a actor one.
