I own a LG OLED 65 C8 TV which just received a new firmware update that enables integration in HomeKit. So now I finally can use HomeKit to turn it on/off (e.g. for a “TV time” scene) and switch TV inputs.
But of course I want to do that with openHAB and not only with the Apple Home app.
I know there is the LG WebOS binding but unfortunately the underlying API is no longer supported and for me it’s really not working well. Most important I can’t turn the TV on using it. So I thought that maybe with the new Homekit integration there is a possiblity to leverage that.
Can openHAB somehow control Homekit items? I know (and use) the other way (openHAB exposing items to Homekit). My first thought was to create a Switch in openHAB and then use Homekit automation to synchronize that with the actual TV, but I don’t own an Apple TV or HomePod, so I can’t use automation. Is there any other way?
Does this python library work ? https://github.com/supersaiyanmode/PyWebOSTV
Although you stated that the underlying API changed nevertheless the last update on the lib was done 2 months ago. May be there is a chance that at least the stuff that you are looking for is working.
Last time I tried was about a year ago. Turning the TV on did not work then. Since @crystollic says it currently works for hin I will try again, thanks for the hint
I installed the LG WebOs binding again and this time it works just fine. No idea why it didn’t last time I tried some time ago…
I also found an old iPad that I could set to be an automation master for my home. So just for reference, it’s also possible to use a proxy item to control this
Proxy item (switch) exposed to HomeKit
WebOS TV in HomeKit
Rule (in Apple HomeKit / Automation tab) that a change of the proxy item should start and action like “turn on the TV”
