I’m not sure if this is possible. I have a front porch light and I want it to come on in response to the front door opening or the outside motion sensor being triggered.
The door sensor toggles between states of OPEN and CLOSED and the motion sensor toggles between states of ON and OFF. Is there a way of creating a group containing these with an OR aggregation function such that the group item returns ON or OPEN if either of the sensors becomes ON/OPEN?
I don’t think so. However, you might be able to use the SUM aggregation function and use the count to know if one or both are open.
Group:Number:Sum FrontSensors
rule "Front Sensors changed"
Item FrontSensors changed
val currCount = FrontSensors.state
if(currCount > previousState) {
// you know that one of the sensors changed to ON or OPEN
else{
// one of the sensors changed to OFF or CLOSED
I don’t know for sure this will work but think it should.
I have tested this today and can confirm that using SUM to aggregate the items does work. I can use FrontSensors.state > 0 to achieve an OR and FrontSensors.state == 2 to achieve an AND.
