I created an switchable item for HomeKit integration with this code:
Switch HK_FRITZ_DECT_200_1_Power "Wohnzimmer" <lightbulb> (gDECT_200_1_Power) [ "Switchable" ] { channel ="avmfritz:FRITZ_DECT_200:192_168_188_1:xxxxxxxxxx:outlet" }
This works fine, I can pair and use the device within HomeKit. As described here it is also possible to create it as outlet. But when I change the code as follows, the item disappears in HomeKit:
Switch HK_FRITZ_DECT_200_1_Power "Wohnzimmer" <poweroutlet> (gDECT_200_1_Power) [ "Outlet" ] { channel ="avmfritz:FRITZ_DECT_200:192_168_188_1:087610070492:outlet" }
The item is still visible in PaperUI but no longer in HomeKit. In the logs I cannot see any error messages. Can anybody help me to figure out what is wrong or missing to get a working outlet item for HomeKit?
I am using openHAB 2.5.4 HomeKit integration service and avmfritz!binding.
