How to create channels when the thing uses separate mqtt topics to get and set status and returns json string?
Thanks for answering so fast.
May be, I am quite new to openHAB. I don’t know the indepths of it.
I am not sure to understand your answer.
The valve will respond for each command but not with just the result or the set value.
It respond with the complete status fo the valve (and you have to extract the info with JSONPATH to see if it did it correctly).
If I understand you well, you say that the best way is just to create separate channels for each value and stablish a JSONPAT to extract the value. (it will have to retrieve the status several times to get al values and extract the value from the answer).
I will try it, then.
