In OH3 I’ve created a few custom widgets using the developer tools, but I can’t find a way to delete them again. I’m probably doing something wrong, but I have no idea how to remove a custom widget again.
When you see the Widget listing (Developer Tools -> Widgets), at the top right there should be text that says ‘select’ , which if you click will allow you to select widgets. As soon as one widget is selected a ‘Remove’ link will appear at bottom left.
Ah, thank you… That works.
