In my handleCommand
method, I want to know if the channel is readonly. I can see there’s an isReadOnly()
method on the ChannelType
class, but I’m just not seeing how to get a ChannelType object given a ChannelUID. I’m sure I’m missing something obvious…
Try channelType.getState().isReadOnly()
Ok. I see that. But how do I get the channelType
object using the ChannelUID
passed into handleCommand
Below is based on my memory.
If you inherit from base thing handlers available in framework then getChannel(channelUID).getType
or getThing().getChannel(...)
to switch from handler to model layer.
That’s what I was hoping… But getThing().getChannel(channelUID)
returns a Channel
object. From there I can get the ChannelTypeUID
. But I still don’t see a way to get the ChannelType
Do I need a ChannelTypeProvider
? If so, how do I get one of those?
You’re right - I went over IDE just now and it seems you need to make an extra mile with ChannelTypeRegistry
which will allow you to exchange channel type uid for its model instance.
That was it. Need to inject that into the thing handler. Works perfectly! Thanks!!!
