I’m trying to make a rule that triggers when I switch on a hue light using its physical switch. But I cannot get the rule to trigger.
My items look like this:
Switch KI_CeilingLamp “Kök - Taklampa” (Kitchen,Lights) { hue=“2” }
Dimmer KI_CeilingLamp_Dimmer “Kök - Taklampa, dimmer” (Kitchen,Lights) { hue=“2” }
The rule looks like this:
rule “Scene Hue feedback”
Item KI_CeilingLamp_Dimmer changed
if(KI_CeilingLamp_Dimmer.state == 100)
KI_CeilingLamp_Dimmer.sendCommand(50)
I also tried several variations, like triggering on the switch item of the light. It did trigger once or twice when I turned the light on, which makes me think this might be a timing issue. The refresh rate of the Hue binding is set to 2000msec.
Any suggestions on how to achieve this?
