Is it possible to retrieve temperature information by Amazon Echo to be shown in OH? If so, I could add a sitemap string showing the current temperature in OH app.
I have here a thing in the Echocontrol binding “Alexa Guard on Echo” which offers also a temperature channel.
I have no need for this but I think you can create a link and show on your sitemap so.
Hi, I cannot find this “Alexa Guard on Echo”, please drive me in.
I already have my Echo thing previously add by “Amazon Echo Control Binding”, which already linked “Speak” channel (the one I use to make Alexa speaking the string sent by OH)
There are a lot of other available channels, related to music, volume, radio, Bluetooth… but no one referring to temperature.
Please post some screenshots so I can see where you found that feature, thanks
But I am not sure if this feature is available in all countries, I am from Austria so on amazon.de.
I have an Echo Dot V4, maybe it is not available on older versions.
Most (not sure if all) show two or more things in discovery. One is of type echo (or similar) and the other are of type smartHomeDevice. If you do not see a thing with the latter type, check in your account thing if discovery for smarthome devices is enabled. You have to select at least “direct connected”. Do not select “direct, over alexa an openhab skill” if you don’t know what you are doing.Do a scan and you should see the devices.
In the meantime, could you please screenshot the OH page where you find this “Alexa Guard” thing which has the temperature channel inside?
Just to realize how your found things differs from mine, thank you.
