I have several tasmota devices with configured LWT topics. These devices can be online/offline freaquently. Is it possible to have the controls which belong to the device displayed as disabled in the sitemap? What other options can I use to understand the device is offline?
Hi Serhiy,
as far as I know, there is no way to mark controls as disabled or “grayed-out”.
But you can make the controls invisible if the device is offline:
Disable a Oh-button - Add-ons / UIs - openHAB Community
It’s possible.
Just have an item that represents the status of your tasmota device (e.g. link it to the LWT topic as its stateTopic) and use that item in your disabled:
config.
label: test
sidebar: true
blocks:
- component: oh-block
config: {}
slots:
default:
- component: oh-grid-row
config: {}
slots:
default:
- component: oh-grid-col
config: {}
slots:
default:
- component: oh-toggle-card
item: TestSwitch1
disabled: =items.TestSwitchEnabled.state == "OFF"
config: {}
slots:
default:
item: TestSwitchEnabled
masonry: null
grid: []
canvas: []
OP is asking about sitemaps so the approach will be a little different.
@svh, unless a new feature has been added to sitemaps that is not in the docs, the best approach for this is going to be to create the status Item like @jimtng describes. Then you’ll have two entries in your sitemap for the Item, one with the control enabled (e.g. Switch element) and the other one with the control disabled (Text element). Use the status Item to control the visibility of each sitemap element so one is only shown when the status says it’s online and the other only when the status says it’s offline.
@Mandrill Yes, thanks, I’m aware about this option but was hoping to find better approach
@jimtng Haven’t managed to switch to the new lyaout yet
@rlkoshak Another option I was considering is to change signal level icon (which shows rssi) to off. But did not get how to properly use 2 data sources for dynamic icons. It should be available in OH4?
I don’t think that’s possible in sitemaps.
not sure if it helps or if it’s 100% what you want…
I have e.g.
Text item=NW_TPAP valuecolor=[NW_TPAP==ON="green", ==OFF="red"] visibility=[NW_TPAP!=ON]
Text item=NW_TPAP valuecolor=[NW_TPAP==ON="green", ==OFF="red"] visibility=[NW_TPAP==ON]
Webview url="/static/inject_autolinker.html" visibility=[Flag_System==OFF]
Text item=NW_TPAP_URL
which results in:
or
the real “controls” are one sublevel below and can just be accessed, when item is online.
for “just” disabling a control I also did not find any solution in the past.
