Platform information:
- Hardware: _Raspberry Pi
- OS: Raspbian + openHab
- openHAB version: openHab 2
Issue of the topic:
I have installed the “telegram” binding and use it to send alerts. That works fine! Now I want to display the text and the date/hour of the last telegram sent on the webpage default.sitemap. And that’s the problem.
in my items-file I have:
// Strings
String LastTelegram "[%s]"
String LastTelegramTime
String PlaceFiller
// -----------------------------------------------------------------------end of Strings
in my rules I have:
// Battery control
rule "control motion sensor Hall battery level"
Time cron "0 0 11 ? 1/1 SAT#1 *"
var myText = "Hall motion sensor battery level is: "+MotionHallBattery.state
val telegramAction = getActions("telegram","telegram:telegramBot:db7f3715")
telegramAction.sendTelegram(myText)
logInfo("Rules", "...Battery Telegram sent.")
in my default.sitemap I have:
sitemap default label="at Home...."
Frame label="Date, Time ..." {
Text item=DateNow label="Today: "
Text item=Season label="Season: "
Text item=SunriseStartTime label="Sunrise: "
Text item=SunsetStartTime label="Sunset: "
Frame label="Telegram..." {
Text item=LastTelegram label="last text sent: "
Text item=LastTelegramTime label="at: "
Now I would like to display myText from the rules in the LastTelegram from the sitemap and the date/time of the telegram in LastTelegramTime. It doe not work… any Help is welcome!
