How to escape colon (:) in Item REGEX transformation
I have an MQTT message which looks like this:
TIME:0,INTE:21.90,INHU:33.68
I am trying to bind the INTE key’s value (in this example 21.90) to a Number item using a REGEX transformation. It wasn’t working, so I made it a String, and matched the entire message with REGEX:
String main_temperature "mainT [%.1f]" {mqtt="<[seal:weather:state:REGEX((.*))]" }
That worked, i.e. it gave the entire message. I added more of the message outside the capture group, and eventually got the value I wanted with this REGEX:
String main_temperature "mainT [%.1f]" {mqtt="<[seal:weather:state:REGEX(.*INTE.(.*),.*)]" }
Notice the single character pattern match “.” just after INTE to match the colon in the message. I would rather have an explicit colon, but this binding
String main_temperature "mainT [%.1f]" {mqtt="<[seal:weather:state:REGEX(.*INTE:(.*),.*)]" }
gives me an error, I think becase it sees the colon and thinks I am on to the next clause in the MQTT binding,
2017-12-28 13:25:29.196 [ERROR] [.mqtt.internal.MqttMessageSubscriber] - Error processing MQTT message.
java.util.regex.PatternSyntaxException: Unmatched closing ')' near index 6
And if I try escaping the colon like this “\:”
String main_temperature "mainT [%.1f]" {mqtt="<[seal:weather:state:REGEX(.*INTE\:(.*),.*)]" }
I get an error about bad configuration:
2017-12-28 13:27:50.993 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'mqtt.items' has errors, therefore ignoring it: [4,46]: mismatched character ':' expecting set null
[4,82]: mismatched input '(' expecting RULE_STRING
[4,87]: mismatched input '.' expecting RULE_ID
[4,91]: mismatched character '<EOF>' expecting '"'
How do I exactly match a colon in MQTT binding REGEX?
have you tried to use %3A (or %%3A) ? I don’t use MQTT with that but it works for the HTTP binding.
Good idea, but neither of those worked. They both give a NULL result, I guess because the message never matches?
I don’t think this can be done. The MQTT config parser, as far as I’ve been able to tell, has no way to escape the : inside the REGEX. So when it sees the : it thinks you are done with that field and have moved on to the next one which results in an invalid MQTT config.
You can narrow it down a bit from . and have it only match characters that are not white space, digits, or letters:
String main_temperature "mainT [%.1f]" {mqtt="<[seal:weather:state:REGEX(.*INTE[^\w\s](.*),.*)]" }
Thank you both. I have something workable, so not the biggest issue.
If anyone else comes across this, don’t forget to switch back to Number after getting the pattern matching right. And consider using a test item name, especially if you want to persist the item.
Have you tried this: Regular Expressions Reference: Special and Non-Printable Characters?
There should be a number of ways to escape the colon, although I don’t know which, if any, work in OpenHAB. Also found this, that might be of interest.
A double backslash works to escape the colon. I have this Item binding now working:
Number mainfloor_temperature "mainT [%lf]" {mqtt="<[seal:weather:state:REGEX(.*TIME.0,INTE\\:(.*),.*)]" }
Thank you for the clue, Mikael. Seems like openhab uses java’s regexp language, which makes sense.
