I have a smoothly running Zigbee network using the OH Zigbee binding via an Ember EM35x Coordinator. So far, all my Osram plugs could be found and integrated in the last days.
I’m not at all familiar with the device, but if it’s new, then possibly it requires a new version of the coordinator to work with ZB3.0 devices. What version are you using?
So that means my stick supports Zigbee 3.0 and should work?
I just found out that in case of ZB3.0, I maybe need to provide some code. I have to give it at “Install code” in the binding, right?
There is a QR code on the lamp saying
HUE:Z:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX where XXX… should be the code, I hope. But copied it to the install code field without success.
When using an Amazon Echo Plus, the lamp can be included using the built-in Zigbee-Hub. But it requires the six-digit serial number. Not sure how this relates to a key…
Again, I don’t have this device, so don’t know what the serial number is. I’m guessing it’s not related. Normally there is an install code, from which a link key is generated, but lots of other stuff happens under the hood, but unless you have a sniffer, I can’t really help much more.
I’ve not come across any devices that actually require the install code - most will work fine with the standard link key. The only time I’ve needed to use the install code in a product we certified was in a SmartEnergy system which uses a much higher degree of security.
