Hi all,
after spending few evenings on trying to configure openhab (both 3 and 2) to work with my house KNX system, I need to ask for help.
I was able to configure router, added generic KNX device and added a channel with device, everything appears as online, but when I perform ‘turn on/turn off’ action (in Openhab), nothing happens. I’m not sure if this is relevant, but I don’t have any KNX buttons installed as everything works on ‘doorbell buttons’ able to provide an action for short and long press.
I also wonder if the address of my device (lamp) is correct - below you can see an action to turn on/turn off from physical switch captured in ETS. I’ve seen in the documentation usually addresses looks like that 3/0/4+<3/0/5, but I see only one address when capturing traffic in ETS Group Monitor.
Log is clear, I see in events command is being sent, no errors in openhab log. Configured and tested this behaviour in both Openhab 2 and 3.
Any ideas how to move forward?
Thanks in advance!
