I need please help to find the reason for:
Control process exited, code=exited, status=1/FAILURE
sudo grep openha /var/log/*
/var/log/syslog:Nov 7 06:36:48 raspberrypi systemd[1]: openhab2.service: Control process exited, code=exited, status=1/FAILURE
/var/log/syslog:Nov 7 06:36:48 raspberrypi systemd[1]: openhab2.service: Failed with result ‘exit-code’.
/var/log/syslog:Nov 7 06:36:48 raspberrypi systemd[1]: openhab2.service: Service RestartSec=100ms expired, scheduling restart.
/var/log/syslog:Nov 7 06:36:48 raspberrypi systemd[1]: openhab2.service: Scheduled restart job, restart counter is at 2.
I have a komplex rule wich is interacting with the homematic binding, the sonos binding and many unix shell scripts. The unix shell scripts create pictures and create and updates many unix files.
The problem is that the rule is running for more than many (50) times without having problems and than without seeing a pattern when the rule is running openhab crashs after or at the end of the rule. The only thing I found is the log
After this openHAB starts new and I can use the rule again without problems for many times.
I did have a look at a memory leak issue but did see anything.
I use openHAB 2.4 with Zulu and I reinstalled openHAB, Raspbian is even updatet.
pi@raspberrypi:/var/log $ java -version
openjdk version “1.8.0_152”
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
But the question is WHY.
Please help me.
What can I do to find the reason
THX for your help…
Regards
Klaus
