Hello thanks a lot for your nigthly answer.
But it didn’t work.
I changed it the following way:
Rollershutter Jal_Kueche "Küche UP/DOWN" {channel="digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e:shade"}
Dimmer Jal_Kueche_W "Küche Winkel" {channel="digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e:shadeAngle"}
Frame label="Wetter" {
Text item=Clouds
Slider item=Jal_Kueche
Switch item=Jal_Kueche
Slider item=Jal_Kueche_W
Switch item=Rol_WohnTe
Slider item=Rol_WohnTe
Text item=NLWetterlage
The result is: The slider and switch of “Jal_Kueche” is working.
the Slider for “Jal_Kueche_W” does nothing.
Because of your comment, that the item may not be created, I checked my openhab.log File for “digitalstrom” entries.
I found follwing entry
Line 14685: 2016-07-23 00:14:40.710 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Jal_Kueche_W-digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e:shadeAngle' has been added.
Later on, when I move the ShadeAngle Slider I will have the follwoing entries:
Line 15195: 2016-07-23 00:18:40.611 [WARN ] [g.digitalstrom.handler.DeviceHandler] - Command sent to an unknown channel id: digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e:shadeAngle
If I compare that entry with the working entry of shade changes
Line 15212: 2016-07-23 00:18:53.184 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_GR_303505d7f800182000000a96_3504175fe00000000005932e_shade changed from 73 to 56
I see a naming difference. The shade item is divided by “_” the ShadeAngle Item by “.” May be that is the problem?
Following I send you all my digitalstrom entries after reboot. May be you will see something
Line 14432: 2016-07-23 00:13:17.060 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower changed from 213 to 210
Line 14433: 2016-07-23 00:13:17.096 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.081000000000130967237055301666259765625 to 1440.08300000000008367351256310939788818359375
Line 14437: 2016-07-23 00:14:19.928 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600' has been added.
Line 14438: 2016-07-23 00:14:19.954 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613' has been added.
Line 14439: 2016-07-23 00:14:19.960 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' has been added.
Line 14440: 2016-07-23 00:14:19.965 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' has been added.
Line 14441: 2016-07-23 00:14:19.970 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'digitalstrom:dssBridge:303505d7f800182000000a96' has been added.
Line 14547: 2016-07-23 00:14:20.665 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'digitalstrom_GR_303505d7f800182000000a96_303505d7f8000f0000088600_shade' has been added.
Line 14548: 2016-07-23 00:14:20.668 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'digitalstrom_GR_303505d7f800182000000a96_303505d7f8000f0000088600_shade-digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600:shade' has been added.
Line 14549: 2016-07-23 00:14:20.695 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'digitalstrom_GR_303505d7f800182000000a96_303505d7f8000f0000088613_shade' has been added.
Line 14550: 2016-07-23 00:14:20.698 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'digitalstrom_GR_303505d7f800182000000a96_303505d7f8000f0000088613_shade-digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613:shade' has been added.
Line 14551: 2016-07-23 00:14:20.702 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'digitalstrom_GR_303505d7f800182000000a96_3504175fe00000000005932e_shade' has been added.
Line 14552: 2016-07-23 00:14:20.706 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'digitalstrom_GR_303505d7f800182000000a96_3504175fe00000000005932e_shade-digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e:shade' has been added.
Line 14553: 2016-07-23 00:14:20.709 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'digitalstrom_appScene_303505d7f800182000000a96_0_0_88_scene' has been added.
Line 14554: 2016-07-23 00:14:20.712 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'digitalstrom_appScene_303505d7f800182000000a96_0_0_88_scene-digitalstrom:appScene:303505d7f800182000000a96:0-0-88:scene' has been added.
Line 14555: 2016-07-23 00:14:20.716 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower' has been added.
Line 14556: 2016-07-23 00:14:20.719 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower-digitalstrom:dssBridge:303505d7f800182000000a96:totalActivePower' has been added.
Line 14557: 2016-07-23 00:14:20.723 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter' has been added.
Line 14558: 2016-07-23 00:14:20.728 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter-digitalstrom:dssBridge:303505d7f800182000000a96:totalElectricMeter' has been added.
Line 14563: 2016-07-23 00:14:27.570 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600' changed from UNINITIALIZED to INITIALIZING
Line 14564: 2016-07-23 00:14:27.607 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613' changed from UNINITIALIZED to INITIALIZING
Line 14565: 2016-07-23 00:14:27.619 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' changed from UNINITIALIZED to INITIALIZING
Line 14566: 2016-07-23 00:14:27.634 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' changed from UNINITIALIZED to INITIALIZING
Line 14567: 2016-07-23 00:14:27.698 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:dssBridge:303505d7f800182000000a96' changed from UNINITIALIZED to INITIALIZING
Line 14568: 2016-07-23 00:14:27.712 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:dssBridge:303505d7f800182000000a96' changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING): Checking configuration...
Line 14569: 2016-07-23 00:14:27.732 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14570: 2016-07-23 00:14:27.732 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600' changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14571: 2016-07-23 00:14:27.735 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613' changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14572: 2016-07-23 00:14:27.744 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14573: 2016-07-23 00:14:27.747 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to OFFLINE (BRIDGE_OFFLINE)
Line 14574: 2016-07-23 00:14:27.754 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to OFFLINE (BRIDGE_OFFLINE)
Line 14575: 2016-07-23 00:14:27.754 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to OFFLINE (BRIDGE_OFFLINE)
Line 14576: 2016-07-23 00:14:27.758 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613' changed from OFFLINE (BRIDGE_OFFLINE) to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14577: 2016-07-23 00:14:27.762 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' changed from OFFLINE (BRIDGE_OFFLINE) to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14578: 2016-07-23 00:14:27.766 [INFO ] [g.digitalstrom.handler.BridgeHandler] - Loading configuration
Line 14579: 2016-07-23 00:14:27.778 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to OFFLINE (CONFIGURATION_PENDING): Waiting for building digitalSTROM model.
Line 14580: 2016-07-23 00:14:27.795 [INFO ] [g.digitalstrom.handler.BridgeHandler] - Checking connection
Line 14583: 2016-07-23 00:14:29.303 [INFO ] [g.digitalstrom.handler.BridgeHandler] - Initializing digitalSTROM Manager
Line 14600: 2016-07-23 00:14:30.325 [INFO ] [g.digitalstrom.handler.BridgeHandler] - Building digitalSTROM model
Line 14602: 2016-07-23 00:14:30.664 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'digitalstrom:dssBridge:303505d7f800182000000a96' has been updated.
Line 14603: 2016-07-23 00:14:30.958 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower changed from NULL to 211
Line 14604: 2016-07-23 00:14:31.038 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from NULL to 1440.08699999999998908606357872486114501953125
Line 14605: 2016-07-23 00:14:31.049 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to OFFLINE (CONFIGURATION_PENDING): Checking configuration...
Line 14606: 2016-07-23 00:14:31.249 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600' has been updated.
Line 14676: 2016-07-23 00:14:40.668 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600' has been updated.
Line 14677: 2016-07-23 00:14:40.678 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:dssBridge:303505d7f800182000000a96' changed from OFFLINE (CONFIGURATION_PENDING): Checking configuration... to ONLINE
Line 14678: 2016-07-23 00:14:40.685 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Rol_WohnTe-digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600:shade' has been added.
Line 14679: 2016-07-23 00:14:40.686 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to ONLINE
Line 14680: 2016-07-23 00:14:40.689 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_GR_303505d7f800182000000a96_303505d7f8000f0000088600_shade changed from NULL to 0
Line 14681: 2016-07-23 00:14:40.693 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' changed from OFFLINE (BRIDGE_OFFLINE) to OFFLINE
Line 14684: 2016-07-23 00:14:40.704 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Jal_Kueche-digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e:shade' has been added.
Line 14695: 2016-07-23 00:14:40.842 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613' has been updated.
Line 14825: 2016-07-23 00:14:49.020 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088613' has been updated.
Line 14826: 2016-07-23 00:14:49.025 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' changed from OFFLINE to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14827: 2016-07-23 00:14:49.029 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to ONLINE
Line 14828: 2016-07-23 00:14:49.161 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' has been updated.
Line 14883: 2016-07-23 00:14:56.832 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' has been updated.
Line 14884: 2016-07-23 00:14:56.849 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' changed from OFFLINE (CONFIGURATION_PENDING): Waiting for building digitalSTROM model. to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14885: 2016-07-23 00:14:56.854 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to OFFLINE (CONFIGURATION_PENDING): Waiting for listener registration
Line 14886: 2016-07-23 00:14:56.941 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:appScene:303505d7f800182000000a96:0-0-88' changed from OFFLINE (CONFIGURATION_PENDING): Waiting for listener registration to ONLINE
Line 14887: 2016-07-23 00:14:56.949 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_appScene_303505d7f800182000000a96_0_0_88_scene changed from NULL to OFF
Line 14888: 2016-07-23 00:14:56.953 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600' changed from OFFLINE (CONFIGURATION_PENDING): Checking configuration... to OFFLINE (CONFIGURATION_PENDING): waiting for listener registration
Line 14889: 2016-07-23 00:14:56.959 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'digitalstrom:GR:303505d7f800182000000a96:303505d7f8000f0000088600' changed from OFFLINE (CONFIGURATION_PENDING): waiting for listener registration to ONLINE
Line 15061: 2016-07-23 00:15:01.342 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.08699999999998908606357872486114501953125 to 1440.087999999999965439201332628726959228515625
Line 15166: 2016-07-23 00:15:32.103 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower changed from 211 to 202
Line 15167: 2016-07-23 00:15:32.134 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.087999999999965439201332628726959228515625 to 1440.091000000000121872290037572383880615234375
Line 15170: 2016-07-23 00:16:03.169 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.091000000000121872290037572383880615234375 to 1440.093000000000074578565545380115509033203125
Line 15173: 2016-07-23 00:16:34.133 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower changed from 202 to 200
Line 15174: 2016-07-23 00:16:34.186 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.093000000000074578565545380115509033203125 to 1440.0940000000000509317032992839813232421875
Line 15177: 2016-07-23 00:17:05.118 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.0940000000000509317032992839813232421875 to 1440.09600000000000363797880709171295166015625
Line 15180: 2016-07-23 00:17:36.129 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower changed from 200 to 201
Line 15181: 2016-07-23 00:17:36.168 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.09600000000000363797880709171295166015625 to 1440.097999999999956344254314899444580078125
Line 15184: 2016-07-23 00:18:07.128 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower changed from 201 to 200
Line 15185: 2016-07-23 00:18:07.184 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.097999999999956344254314899444580078125 to 1440.098999999999932697392068803310394287109375
Line 15190: 2016-07-23 00:18:36.674 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_GR_303505d7f800182000000a96_3504175fe00000000005932e_shade changed from NULL to 73
Line 15192: 2016-07-23 00:18:37.834 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalActivePower changed from 200 to 202
Line 15193: 2016-07-23 00:18:37.874 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.098999999999932697392068803310394287109375 to 1440.10100000000011277734301984310150146484375
Line 15205: 2016-07-23 00:18:47.816 [WARN ] [g.digitalstrom.handler.DeviceHandler] - Command sent to an unknown channel id: digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e:shadeAngle
Line 15228: 2016-07-23 00:19:02.287 [WARN ] [g.digitalstrom.handler.DeviceHandler] - Command sent to an unknown channel id: digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e:shadeAngle
Line 15230: 2016-07-23 00:19:02.955 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'digitalstrom:GR:303505d7f800182000000a96:3504175fe00000000005932e' takes more than 5000ms for processing event
Line 15231: 2016-07-23 00:19:16.349 [INFO ] [marthome.event.ItemStateChangedEvent] - digitalstrom_dssBridge_303505d7f800182000000a96_totalElectricMeter changed from 1440.10100000000011277734301984310150146484375 to 1440.1030000000000654836185276508331298828125
