Within HabPanel I configured a Selection Widget with the openHAB Item: A Jason
but with this configuration I just get the complete json file as value and not just 23,7 C or 52% (depending on JSONPATH Index)
Hope anyone of you can give me a hint…
I’ve tried with html code and http-binding + Regex … nope …
I’ve tried with json and getvalue.js … nope …
I’ve tried this variant with JSONPATH … nope …
in every case values are NULL or everything
thanks a lot
BR Martin
P.S.: If you have any other ideas don’t hesitate to post here!
I’ve a custom Object and are able to transform this to json or html code or another custom format.
I guess you could use a cron rule to populate the required fields using jsonpath transformation at certain intervals. Some code below to test in a rule
val jsonString = sendHttpGetRequest("http://192.168.6.20/mobilealerts.js")
val temp = transform("JSONPATH","$.[0].Value",jsonString)
val fucht = transform("JSONPATH","$.[1].Value",jsonString)
logInfo("Temp is ",temp)
logInfo("Fucht is ",fucht)
thx for your reply, was not able to find a usable documentation (i’m beginner in centos too)
there is no package available on yum and after installing zulu manualy openhab didn’t work.
with install by: yum install java everything seems fine…
may you can give me a hint where i will find a better documentation or post on internet.
thank you
BR Martin
@hmerk: no problem but i think i’ve done the challenge. Now i’m (i hope so) on zulu.
@all: i’ve found an interesting line within logfiles after changing to debug mode:
org.openhab.core.transform.TransformationException: Invalid path ‘$.[1].Value’ in '[
but i’ve no idea why because json validators say everything is fine within json file ?!
EDIT: @MartinKo: I’ve searched through Logfile but did not found any entry like “Temp is” or “Fucht is”.
What i’ve done is creating a file within $openhabdir/conf/rules/test.rules within:
OK… the code I submitted is just the code that is supposed to go into a rule. In other words it is missing the rule skeleton.
You have to provide the rest… like this
rule "update clima"
// run every 10 minutes
Time cron "0 0/10 * 1/1 * ? *"
That only confirms that the json path is OK, but we already knew that. Could you try to modify the rule to the following
rule "update clima"
// run every 2 minutes
Time cron "0 0/2 * 1/1 * ? *"
val jsonString = "[{\"Room \": \"WZ \",\"SensorID\": \"022 A7F181984\",\"Time\": \"16.01 .2018 13: 18: 50\",\"Data\": \"WZTemperatur\",\"Value\": \"23,7 C\"}, {\"Room \": \"WZ \",\"SensorID\": \"064 C1706F7B7\",\"Time\": \"16.01 .2018 13: 19: 45\",\"Data\": \"WZLuftfeuchtigkeit\",\"Value\": \"52 % \"}]"
This is to rule out any problems reading the json from the server and to the OpenHab transformation service. When I run this rule I get the result that is expected
For all they want to use powershell:
curl -X PUT --header “Content-Type: text/plain” --header “Accept: application/json” -d “$current_data” “http://:8080/rest/items/<OPENHAB_ITEM>”
